79 280zx
Old Apr 23, 2014 | 09:57 AM
Josh Smith's Avatar
79 280zx
I bought this car about two years ago I drove it a handful of times it would randomly shut off going down the high way but start right after just turn the key off and back on and it would fire right back up. Now it acts like it is cutting out really bad won't hardly rev up no power. I put all new injectors and fuel pump. Thanks for reading and racking the brain.
Old Apr 23, 2014 | 10:11 AM
Welcome to ZDriver!
Start with a check over of all wiring connections in the engine bay... battery terminals, fusible links, sensors, coil, spark plug wires, grounds, etc. Also check ignition switch.
And when you say "shuts off", do you mean no power at all, or that the engine dies and all the dash lights come on?
Old Apr 23, 2014 | 10:21 AM
Josh Smith's Avatar
I still have power the motor dies though I can pull over and turn it over by he starter or I can turn the switch to off with foot on clutch and turn it back to on and it starts right back up.
Old Apr 23, 2014 | 10:35 AM
Josh Smith's Avatar
Yea the dash lights come on but they all light up randomly it doesn't even have to die for the dash lights to come on.
Old Apr 23, 2014 | 10:38 AM
What does your volt gauge do when this happens?
I'd say it's likely the ignition switch... but could also be a loose ground or dying alternator.
Old Apr 23, 2014 | 10:43 AM
Josh Smith's Avatar
When I rev it up it says it has more voltage but, it is not good I know cause I un hooked the battery when It was running and it died but I thought if I had a good charge it would run till the battery died.
Old Apr 23, 2014 | 02:54 PM
zxguy1986's Avatar
When you "unhooked the battery when (engine) was running" what did you disconnect and where?
Old Apr 25, 2014 | 11:10 AM
Josh Smith's Avatar
The motor hooks to the battery with by the terminal, I un hooked positive and negative and got the same response each time. I jiggled the wiring harness to see if it would make a change in the way it was running, it didn't. Is there any way to tell if it's the ignition, I was also thinking maybe the brain was giving me wrong signals. Think you for the input guys
