65mm t/b
Old Jun 20, 2012 | 11:14 PM
zordietrying's Avatar
65mm t/b
I'm looking for a 65mm t/b, I already have a 60mm off a 240sx but would realy like to use a 65mm. In my search I found you can use one from a 73-74 v8 mercedes but I have had no luck finding one at my local junk yards. Is there another car with a 65mm t/b that could be used? Maybe a mustage. Or would it be easyer for me to pick one up from summit?
Old Jun 21, 2012 | 12:07 AM
Why do you think you need one? You know you could get the same results by just switching to a larger pulley on the TB right?
Old Jun 21, 2012 | 08:14 AM
5mm difference is huge!!!
Adding 5psi to each tire will give you better results, and is free.
Old Jun 21, 2012 | 03:09 PM
Going from 50mm to 60mm is only a 10mm difference, that's a 50% increase just going 5 more mm.
Old Jun 22, 2012 | 10:12 AM
Have you ported your intake runners?
Have you upgraded to a larger turbo?
Have you installed larger cc fuel injectors?
Are you running a tunable ecu?
Are you running 2.5in+ intercooler pipes?
If not... you have those things to do before the need of a 65mm throttle body.
Old Jun 22, 2012 | 10:17 PM
Well I'm working on all that stuff so with my new manifold that I'm working on to go with all those other upgrades, I'm going with a 65mm throttle body. So any info on another 65mm throttle body besides the 74 mercedes?
zpeedracer25
Nov 10, 2005 08:52 PM
