3rd gear hesitation
Old Jan 26, 2004 | 12:23 AM
duckyz's Avatar
3rd gear hesitation
In my '83 n/a, when I'm romping on it, sometimes there's a wierd hesitation before the motor starts rolling. Even then, it's not "quite right".
I get the same hesitation just rolling along on the highway around 78mph (3100ish rpm).
Any ideas or thoughts what this might be???
Old Jan 28, 2004 | 08:06 PM
duckyz's Avatar
No one....? Maybe an insect in the air filter? or something.....?
Old Jan 29, 2004 | 04:35 AM
lifegrddude's Avatar
Externally Wastegated
Just throwing an idea, but maybe a slipping clutch? Or possibly the timing could be a bit off.
John 82ZXT
Old Jan 29, 2004 | 09:44 AM
Check out your ignition. Make sure the rotor has good motion. Take off the cap and twist the rotor with your hand. Let it snap back into place. This will assure your mechanical advance is working properly.
check the position of the adjusting nut at the base of the distributor. It should be in the middle with a little bit of gap on either side. The little 10mm bolt rests in a slot. Losen that bolt, thurn the distributor counterclockwise a little untill the gap is just barely gone. (the lower end, towards the driver's side) This will advance your ignition a litte. If your mechanical or vaccume advance is messed up, advance the distributor all the way with the adjustment I just described.
Now drive your car and see if that helped. If it did then something was wrong with your ignition. Maybe even just replace your spark plug wires and spark plugs.
Old Jan 29, 2004 | 12:30 PM
Jimmys83Z's Avatar
I suggest change your air and fuel filters if not done so already and checking adjustment on TPS as well as checking the ignition as mentioned above............
Old Jan 29, 2004 | 05:33 PM
duckyz's Avatar
I did the air/fuel filter thing....I'll mess with the timing this weekend. It just seems wierd that it only happens in third...
Old Feb 23, 2004 | 07:30 PM
duckyz's Avatar
Sorry for the delay......My timing's just fine.
Seems like the old gal just doesn't like cold weather.
duckyz
Aug 2, 2008 12:09 PM
84z31nonturbo
Apr 15, 2008 04:18 AM
KENZ
Aug 18, 2005 11:13 PM
Nathan_S
Jul 22, 2003 06:13 PM
beechkingd
Apr 30, 2003 05:15 PM
