280zxt hot start problem?
Old Jul 15, 2008 | 02:46 PM
zstreet86's Avatar
my 83 280zxt starts up great cold, idles great drives great, but then after i try to start it again while its still hot, it just cranks. it seems like it only acts up like this after the engine is hot, like a temp sensor could be bad or something. could the CHTS be the culprit? its had me runnin in circles and i just wanted to see if anyone knows anything off the top of their head. thanks guys and gals!
Old Jul 15, 2008 | 02:57 PM
When a car won't start, it's one (or both) of these main problems:
#1... no spark
#2... improper fuel delivery.
Do you have spark at the plugs? Are the injectors spraying?
Old Jul 15, 2008 | 03:04 PM
zstreet86's Avatar
im going to have to run down the list and test everything after its hot and i turn it off. in the mean time ill just have to leave it running if i take it somewhere lol.
Old Jul 15, 2008 | 03:17 PM
duowing's Avatar
NisTuner
you tried opening the throttle while cranking?
Old Jul 30, 2008 | 07:48 PM
michanic220's Avatar
check you're compression when the engine is warm at running temp. you should have above 100psi on each cyl.
Old Jul 30, 2008 | 07:50 PM
KasbeKZ's Avatar
Pr0n Addict
i'd go ahead and do the temperature sensor. i've seen a bad temp sensor do the exact same thing to a honduh
zstreet86's Avatar
unfotunately i've been out of town and wont be back for another two weeks, but ill post back in this thread when i see whats up. thanks again guys
Old Aug 11, 2008 | 01:45 PM
zstreet86's Avatar
ok im back and have checked it out again. right now my current theory is the ignitor. right now the car doesnt start at all now.... no spark. so maybe it was shorting out and has now gone out completely? i cant find my damn haynes manual cuz i was trying to see if it shows a way to test the ignitor. So can one of you please help me out with this? thanks in advance
Old Aug 11, 2008 | 02:18 PM
Niku-Sama's Avatar
eff good grammar
sounds alot like this:
https://www.zdriver.com/forums/280zx-s130-forums-77/overheating-distributor-26345/
Old Aug 11, 2008 | 09:05 PM
zstreet86's Avatar
yes exactly, you can also see i posted in that thread, but i need to know how to test the ignitor to see if it works... thanks
Old Aug 11, 2008 | 10:06 PM
Here's a scan from the Haynes manual... Also, just an FYI: you can download the FSM from www.xenons130.com
Old Aug 12, 2008 | 11:53 AM
zstreet86's Avatar
man thanks a lot ill let you know what i find out
Old Aug 13, 2008 | 05:13 PM
zstreet86's Avatar
ok the secondary circuit resistance on the coil was slightly higher than what it should be, so i replaced it. the ignitor seems ok... there still no spark and i did some further checking and i dont have any pulsing to the injectors now either. this makes me want to go back to the crank angle sensor/distributor. i found my haynes manual finally and both that and the 83 fsm doesnt seem to show how to test/check the cas or distributor, i was hoping someone could help me in trying to figure out if my dizzy was faulty, also if you have any other ideas or suggestions for me. thanks!
Old Aug 21, 2008 | 01:43 PM
zstreet86's Avatar
ok i replaced the distibutor with a used one and still the same thing. i'm out of ideas guys. i need some help!
Old Aug 21, 2008 | 01:51 PM
Mhinrichs's Avatar
Mr. Fancy Connectors
try this. unplug the igniter and stick your multi meter probes inside the plug so you make contact, then tell me what the reading is with the key on. Then have someone start it and tell me what the reading is there. Also, just above your ecu is a couple of modules. When its running touch those and tell me if they are hot. Specifically the one running your fuel pump.
Old Aug 21, 2008 | 07:22 PM
zstreet86's Avatar
sure ill go back and write down the readings. since it doesnt run i wont be able to do the touch/hot test for the fuel pump module if i understood you correctly... check back tomorrow afternoon/evening for results. and thanks a lot
Old Aug 22, 2008 | 06:00 PM
zstreet86's Avatar
sorry i didnt get the chance to mess with it today. Mhinrichs i will post up info as soon as i can thanks.
Old Aug 22, 2008 | 06:21 PM
Mhinrichs's Avatar
Take your time, I`m in no hurry.
Old Aug 27, 2008 | 03:50 PM
zstreet86's Avatar
i sent you a pm mhinrichs...
Old Aug 30, 2008 | 03:59 PM
PooFlinginMonke's Avatar
Your return line could be clogged which does not allow cold fuel from the tank flush out hot fuel that is surely bubbling after a hot soak.
If you turn on the key a few seconds and back off a few times before trying to start the car it should start right away since this allows the bubbling volume of vapors in the rail to be compressed back down to liquid.
Old Aug 30, 2008 | 04:03 PM
zstreet86's Avatar
this sounds like a good theory. i will definately keep this in mind. right now my focuses are on my no start ignition problem. i am beginning to think that it is possible i replaced the ignitor with another faulty one. one of the downsides of trying to find deals on used parts. i will definately keep you guys updated...
Old Sep 7, 2008 | 09:36 AM
zstreet86's Avatar
i tried yet another used ignitor and coil yet still no spark. could the computer have went out? what is this thing that runs to the back of the distributor?
Old Sep 7, 2008 | 10:35 AM
Mhinrichs's Avatar
That thing is a resistor, it doesn't really need to be attached but its there so cant hurt. To test the cas you need an oscilloscope, as it pots out square wave signal. As for the computer look at the side of it and see if the green light is on, then find someone to let you plug their computer in and see if that resolves the issue.
Old Sep 7, 2008 | 10:43 AM
duowing's Avatar
NisTuner
A CAS issue maybe?
Old Oct 27, 2008 | 09:48 PM
runningjalapeno's Avatar
it might be the distibutor my z was doing the same i replaced it runs fine now ,except i ahve one problem now its running to rich and my spark plugs are all fouled up any ideas?
