280zxt dist in 280zx NA?
Are you sure about that? You better ask your friend's exactly what they did. First of all, I don't know of any real differences in a 280Z and 280ZX ignition system so I'm not sure why you think a 280Z is more simple.
Maybe they run a 280ZX distributor on a 240Z? That I've heard of. As far as a turbo goes, I don't think it would work... but I could be wrong. I already looked into it and from my research it was not a good swap.
What you could do is use the whole trubo engine and distributor. That would give you some more power.
a turbo dist on a na?
why don't you put some desiel in your tank to make matters worse.
the turbo timing is about 18 degrees before DTC versus just a few degrees for na/s
there are also 2 different dist for the 81-83 turbos
the 81 has an external cas while the 82-83 is an internal cas
the 83 ECU also will NOT work on any other year turbo (81 or 82)
jb
jb
Distributor choice zx turbo or zx na.
jb
jb
jtessmer
12-21-2011 11:27 AM
