280zxt dist in 280zx NA?
Old 02-19-2005, 03:28 PM
JaYaYsSoHN's Avatar
i searched all the forums and i havent got a real answer for usin a 280zxt distributor in a 280zx NA i was wonderin if the it makes any difference ?? thanks
JaYaYsSoHN is offline
Old 02-19-2005, 07:12 PM
It won't work. The trubo distributor is controled by the turbo ECU for different ignition advance for the forced induction.
Bleach is offline
Old 02-19-2005, 11:57 PM
JaYaYsSoHN's Avatar
Im ask because i know people use the turbo distributor on the 280z's. So if it would work for a 280z which has an even more simple ignition system, y wouldnt it work on my 83 ZX?
Old 02-20-2005, 04:08 PM
Are you sure about that? You better ask your friend's exactly what they did. First of all, I don't know of any real differences in a 280Z and 280ZX ignition system so I'm not sure why you think a 280Z is more simple.
Maybe they run a 280ZX distributor on a 240Z? That I've heard of. As far as a turbo goes, I don't think it would work... but I could be wrong. I already looked into it and from my research it was not a good swap.
What you could do is use the whole trubo engine and distributor. That would give you some more power.
Bleach is offline
Old 02-20-2005, 04:43 PM
Dishonest Ebayer - Don't trust me
1982zxt's Avatar
a turbo dist on a na?
why don't you put some desiel in your tank to make matters worse.
the turbo timing is about 18 degrees before DTC versus just a few degrees for na/s
there are also 2 different dist for the 81-83 turbos
the 81 has an external cas while the 82-83 is an internal cas
the 83 ECU also will NOT work on any other year turbo (81 or 82)
jb
1982zxt is offline
Old 02-20-2005, 09:59 PM
Good to know! thanks. I have an 83 turbo engine.
Bleach is offline
Old 10-28-2018, 06:10 AM
Zebulan9's Avatar
Distributor choice zx turbo or zx na.
jb
Thee best distributor on your 280z na is an 82/83 zx na distributor with the black box module. It's a better dist.upgrade for quicker start up on cold day and great if you have to do smog on your Z. I have a complete harness wired and setup to run on a 75 to 78 z with the 83 Zx turbo distributor and comes with a large air-flow meter looks like from a Ford 5.0 and eliminates cold start valve, thermotime switch and the efi relays. Look under my A/D for 78Z convertable part/out posted a few days ago.
Zebulan9 is offline
jtessmer
12-21-2011 11:27 AM
Twitch
03-26-2009 09:30 PM
280z racer
09-23-2007 09:54 PM
DODthunder
01-01-2006 04:15 PM
amazin
03-08-2002 04:58 PM
Quick Reply: 280zxt dist in 280zx NA?
