1983 280zx digital dash temp
Old Aug 1, 2012 | 03:37 PM
ricksilvia's Avatar
The temp gauge in my digital dash is completely off any suggestions?
Old Aug 1, 2012 | 04:01 PM
rogerz's Avatar
Grumpy & Helpful
get a new sender check the wiring and connectors. download fsm from xenon and check the resistance of the sender.
Old Aug 1, 2012 | 04:05 PM
ricksilvia's Avatar
if the sending unit was bad it would result in a black gauge?
Old Aug 2, 2012 | 05:58 PM
The sender is just a resistor that changes resistance with temperature. It's half of a voltage divider. One side the resistor is a fixed value and on the other side is your temperature controled resistor. The gauge just reads the voltage and displays it as a temperature value. XenonS130 will get you the FSM which will tell you what value the temp sensor should be. You can measure it at the connector to the gauge if you want to verify the connections and wiring at the same time but it's easier to measure the sensor itself.
If the sensor isn't working the gauge will still work (unless the gauge is broken as well) it will just read the wrong value.
The very first thing I fixed on any car was my 240Z temp sensor because the temp gauge wasn't reading - true story.
Old Aug 2, 2012 | 06:47 PM
ricksilvia's Avatar
wow man you really know your stuff thanks much appreciated guess i need a new digital cluster cause i dont think i can just get that individual gauge. its completely black and reading nothing
Old Aug 3, 2012 | 06:54 AM
rogerz's Avatar
Grumpy & Helpful
rick might have a broken wire so no voltage to the sensor
Old Aug 3, 2012 | 12:03 PM
silverzxbullet's Avatar
If u need another cluster i have two.. hit me up if so.
Old Aug 3, 2012 | 04:05 PM
Now is the time to swap in an Analog gauge
Old Aug 5, 2012 | 10:13 AM
ricksilvia's Avatar
i have an after market one like the sort from autozone but its too big for any of the passage ways ive tired to fit it to
Punchiest
Aug 14, 2013 08:45 PM
71OLDS
May 22, 2012 11:37 AM
ZguyECV
Jun 23, 2011 12:13 PM
kansaskeith
Dec 10, 2003 07:07 PM
