Tire Size
Old Sep 26, 2003 | 05:51 PM
Lazerus's Avatar
Tire Size
Well it's time to get new tires on the 280 ( 195's just don't like hard launches very well). Anyways, I was wondering what the biggest tire I could fit on the factory 14" wheels would be. I don't want any rubbing at all. I have a 82 2+2 NA. Thanks.
-Matt
Old Sep 26, 2003 | 09:22 PM
icice9's Avatar
Super Siver & Black Stud
when i had my stock rims i was running 225 60 14
Old Sep 29, 2003 | 09:09 AM
Actually the 225 width is closer. 205/60-15 is the factory tire size for the 280ZX. 195/70-14 is the closest stock size for 14 inch wheels.
225/60-14 is only 0.2% undersize! When your speedometer reads 60 you're traveling 59.9 mph. That is basically perfect.
235/60-14 is oversize by 1.7% Still, you're only 1mph over at 60. If you want that width, it won't change your speedometer reading enough to worry about it.
245/55-14 will also be the proper outside diameter, but those are too wide for 14x6 inch wheels and might not fit inside the fenders.
If you can get some wide 15's, go with 245/50-15.
Old Sep 29, 2003 | 10:44 AM
Lazerus's Avatar
Well I am gonna stick with the stock 14's for now since I also need to get the car painted (some fading on the roof and hood hump) and don't want to put off the paint for very long. So if the 235/60/14 will fit all the way around without any rubbing then that's the way i plan on going. Thanks, Discount Tire said that 205 was as big as they could go and I wanted something a little bigger than that (hell my geo would spin 205's with no prob so I don't even want to know what the Z would do with 'em).
Old Sep 29, 2003 | 05:39 PM
icice9's Avatar
most tires still have the white lettering.. its your choice if you want them on the inside or outside...
Old Sep 29, 2003 | 07:56 PM
Lazerus's Avatar
Yeah I am looking at these Firehawk Indy 500's.
Old Sep 30, 2003 | 09:40 AM
Lazerus's Avatar
Thanks, I'll have to check those out. Basically I am looking to find the cheapest price for just tires since i work at a dealership and I can mount and balance the tires myself. I won't have the road hazard warranty, but I'm also a starving college student so money is tight.
Old Oct 24, 2003 | 05:39 PM
Lazerus's Avatar
Well I got the new 235/60's in the back (had a blowout and didn't have enough money for the front tires). Anyways, car now handles really funny. When I change lanes or anything at about 45ish+ mph then the back end tries to whip around. Would this be caused by the tires or is it probably something else? I was looking at the bushings and they are all pretty old and cracked so that could be part of the problem, but I didn't notice the problem until after I got the new tires. Thanks
-Matt
Old Oct 27, 2003 | 10:03 AM
Lazerus's Avatar
Alright, thanks. Now I just need to add polyurethane bushings to my list of things for the Z.
Old Nov 6, 2003 | 11:35 AM
On my post, that size was suggested as a proper outside diameter tire size. It is up to you if you want to put that on a 6 inch width wheel.
However, I did have a 280ZX once that had some 14x6 inch wheels and 225/60-14 on there. They worked fine.
Gingie
Feb 2, 2014 02:04 PM
malibud
Oct 9, 2012 02:27 PM
bojo68
Jul 16, 2009 12:56 PM
BigRich
Jul 19, 2007 03:33 PM
Fast240Z
Jun 1, 2005 12:58 PM
