help need suggestions!! suspension too soft
hey guys i need some serious tech help here, my car squats pretty bad, and was very noticable at auto-x. my shocks are all kyb gr-2's and seem to work fine (only a coupla years old, no leaks) i need a better spring rate, according to the suspension setup guys at the track, my front end pushing is created from the rear being far too soft. so i need to find out what the stock spring rate is, then figure out what would be a good stiff racing type of spring rate. im not talking comfort here, i want this thing to handle. i can order any type of spring rate i want, just need the goods here guys.
Look through old posts, I think someone here made a list of spring rates of stock springs and aftermarket springs. I think the Suspension Techniques were the stiffest 200# per inch or something like that. You can probably get Afco or Hypercoils the right free height and diameter, but they will have flat ground ends, and cutting them to fit the lower seat might not work too good.
Get your car corner weighted and then call Ground Control and they'll tell you what spring rates will work best on your car.
Then you can see if the rate you want is available from Eibach, Tokico or Suspension Techniques for the stock shock perches. If not, you can go with coil overs and get the correct spring rate.
thanks guys, i think a call to moden motorsports seems to be in order, ross will give me a good deal anyway, nobody around here does corner weights, and bathroom scales dont go that high.
If you really want to put all that money into it for coilovers go ahead, but if you just want it to handle much better and not cost so much then get the ST springs. They're tight and only $200. If yours turns out like mine though, you'll need to cut the back spring a little to even it out. Mine is lower in front by a little. Its firm but just soft enough to keep the tire on the ground.
Get bigger sway bars and be done with it.
i already have the larger sway bar upgrade, my buddy had the energy suspensions springs (which i have now), and they lowered the whole car 1.5", i wasnt too happy with the quality of the ride, or the horrible squat it still had.
Shady try this site: A-1 Racing
If you cant find what you need there then it probably doesnt exist
They've got tons of springs (with tons of rates) and coilover parts so you can peice together your own set based on what you need/have.
i got the tokico springs from MSA.. and its really soft... i think i need to get one thats more hard but i just got these so i wont change it for a while.. maybe just upgraded shocks because i need to get new one anyways...
Corner weighted....hmmm so if the ZX, or say my ZX is roughly 2,800lbs and its is a 50/50 weight distribution then that would be 1,400lbs front and rear then 700lbs per corner dead weight...roughly right? Now how do they rate springs? I have read on some kind of springs...eibachs I think that said something like 300lb springs...but lb what...per square inch, dead weight....????
i doubt its that exact^^^
and hoov, launch? brake? gas? i think his is manual, if not then that would work....for drag racing. were talking auto-x though from what i read. otherwise you would want the car to squat some.
yup were talking auto-x here. if your rear springs are too soft, like most zx rear springs, it causes the front to push badly. if the rear springs are too stiff, it causes the rear to slide, and the front to seem like its sticking. that is why coilovers are so great, there tuneable each car will have diff. characteristics depending on shocks fuel load, etc.
You have to cut off the stock spring perch and then weld on the new coilover perch.
Hit up OlderThanMe. He's the one that originally gave me the link to their website and he has actually installed these on a Z. It was an S30, but still, he may be of some assistance as far as information on these goes. He's got a massive project thread over at HybridZ.
If you don't go with coilovers, then I suggest getting some tokico hp struts and springs. If you use poly bushings all around you should have no squat. I have this set up and it is very stiff, I can't imagine going much stiffer unless its a dedicated race car.
Going back to the orig problem... you want to stop the rear squat without lowering right? Find some 79-83 Mercedes 300D front springs & chop them to the desired height. Thas what I did before buying my Eibachs. No squat at all.
