Front frame reinforcement
Subscribe
May 26, 2012 | 01:54 PM
How I can reinforce the front frame of a 280ZX in order to use in a safe manner an hidraulic jack to lift up the car? If you have pics of a simmilar work, please post them.
Reply
May 26, 2012 | 04:07 PM
Weld up steel plates. Do the floor boards while you're in there.
Just an FYI... you aren't supposed to jack the car from the frame rails.
Reply
May 26, 2012 | 05:58 PM
Quote: Weld up steel plates. Do the floor boards while you're in there.
Hi, NismoPick! Saludos desde Puerto Rico, USA!
I read the Xenon info related with the year of my 280ZX. Steel plates can be welded. Is it possible for you to indicate in a diagram in what specific location you recommend the steel plates be welded? I want to be sure.
Reply
May 26, 2012 | 06:16 PM
It's entirely a custom job that depends on how much you want to repair. You could just weld in 1/8inch plates on the sides and bottom where it bends up to the firewall, if you wanted jack plates. But the floorboards are still weak, so I never jack at the rails. I use a 2x4 piece of wood at the radiator support / tension rod mounts. I place jack stands on the front cross member.
This is the underside of my Z. I did the floorboards but never had enough interest to do the frame rails.
Reply
May 26, 2012 | 06:39 PM
Quote: It's entirely a custom job that depends on how much you want to repair. You could just weld in 1/8inch plates on the sides and bottom where it bends up to the firewall, if you wanted jack plates. But the floorboards are still weak, so I never jack at the rails. I use a 2x4 piece of wood at the radiator support / tension rod mounts. I place jack stands on the front cross member.
Thanks for your response and for the pic.
Reply
Subscribe
