Emergency Brake line adjustment
Old Aug 17, 2004 | 10:05 PM
Zskyline79's Avatar
Question Emergency Brake line adjustment
Okay guys got a question for ya. My nephew has a 81 280zx but his emergency brake line is snaped. Got another line from a local junk yard. But heres the thing we took off the old line and the other line is a bit short on the driver side. I was wonder if there is any way to adjust the line or is there something else i can do so we can get the line on. Any appreciation would be helpful. ty :confused
Old Aug 18, 2004 | 12:24 PM
There is the adjustment at the center of the cable. The line from the brake handle comes back to just in front of the differential. That point has a long adjustment bolt on it. Losen it up to hook up the connections between calipers and then tighten it a bit to take out the slack. Not too tight, or your rear brakes will burn while you drive.
Old Aug 18, 2004 | 07:28 PM
FastZ's Avatar
Follow Bleach's instruction and you will be all set.
Old Aug 19, 2004 | 07:48 PM
Zskyline79's Avatar
ummm thing is was that I thought i could put it back together from the caliper back to the adjustment bolt that you say coming from the handle.
So it would be easier to go from the bolt to the caliper instead of the caliper to the bolt???
Old Aug 20, 2004 | 03:13 PM
Either way should work. Honestly, I have different rear brake calipers than you. Mine is the later style, 82-83.
I'm not sure but maybe the mounting points vary slightly and what I suggested won't work... ? Just losen up the bolt in the middle as much as you can and see if it all goes together. That's all I'm saying.
Old Aug 21, 2004 | 10:04 AM
Zskyline79's Avatar
Talking
ah okay, well we have been trying to go to the caliper to the adjustment bolt and that seems not to work so well try from the bolt to the caliper. Ill give some info on how it goes. ty
masterhufflpuff
Apr 2, 2015 10:28 AM
WanganDevilZ
Jun 23, 2012 06:46 PM
1982_280zx
Jun 9, 2008 09:56 AM
55Gary
Aug 2, 2006 10:33 PM
zbestz
May 25, 2005 08:42 AM
