Camber levels on a race car?
Old Nov 2, 2012 | 07:52 PM
LemonHead's Avatar
For those of you who have a race car, I'm curious to hear how much negative camber front and rear you have found to be ideal. Our Lemons car definitely needs some negative camber, but I'm going to do it by notching the upper strut mounts rather than adjustable camber plates as this will attract the ire of the BS judges at Tech Inspection. I'm tempted to go to around 4 degrees negative in front, maybe a touch less in the back (assuming that can even work in back.) Thanks in advance for your guidance.
Old Nov 3, 2012 | 12:50 PM
Check with Frank on Hybridz
Old Nov 4, 2012 | 11:03 PM
id start around 2 or so first, drive it and see. i wouldnt go more in the rear or your traction under power will not be good. just lowering a 280 with springs makes it a bit slippy in the rear.
Old Nov 5, 2012 | 06:31 AM
ThaPimpShrimp's Avatar
Just build a nice big spoiler
Old Nov 5, 2012 | 06:45 PM
LemonHead's Avatar
Thanks guys, appreciate the info.
Old Nov 5, 2012 | 07:53 PM
I'm assuming you're talking about not adjusting the rear end after you've dropped it making it slippy in the rear (eg you just screwed up the stock geometry )
Old Nov 5, 2012 | 10:14 PM
yeah we put in the lowering springs and my buddy didnt care because he wanted the negative camber to help it corner better and it did that, but under accel with everything else the same would spin even in 4th gear with an n/a. the op wanted the camber negative and this is the price you pay to make it handle. ive driven several cars with the same problem like a mustang and 240sx race cars.
Old Nov 6, 2012 | 10:47 PM
You have to slot the rear cross member and get the geometery back if you want it to handle properly. Limiting the travel with stiffer springs is a great idea as well...
Old Nov 7, 2012 | 07:57 AM
LemonHead's Avatar
Thanks guys. Looks like the rear is a bit more work than I anticipated. I'll go ahead and tackle the front first, looks like they are pretty much at 0 degrees right now. Will see how much I can get out of notching the strut mounts up top.
Old Nov 7, 2012 | 08:42 AM
PurePontiacKid built a crazy adjustable hybrid rear cross member for his slammed 280zx... but looks like he deleted the pics in his thread. He used some Toyota rear cross member setup, chopped and welded them on the Z's rear control arms.
You can also use Mercedes 300D springs for the rear too... if you are on a junk yard budget. I've discussed this many times.
garretthes
Sep 10, 2012 09:19 PM
BlueKitsune
Mar 24, 2009 12:31 PM
calvinD
Jun 1, 2004 05:59 PM
racer5gogo
Mar 10, 2004 04:07 PM
zxturbo
Dec 1, 2002 08:03 PM
