Brake question?//
Old 04-18-2005, 11:15 AM
Bleach is my Hero
s/cL3.0's Avatar
Brake question?//
Is this {REAR ROTOR - Diameter: 10-11/64"} For turbo or non-turbo?? Will it work on a 82 280zx??thx in advance..
s/cL3.0 is offline
Old 04-21-2005, 08:59 PM
I have a present for you...
theramz's Avatar
I have several rotors around and they all measure 10 33/64" with a hat depth of 2 3/8". The brake calipers and brackets are all the same. The only difference I found is the turbo calipers had plastic guides which crack after the years. The pads and other hardware are the same also. When I went to Napa they had different part numbers for each but I had them all side by side and saw no difference. Maybe the pads are a different material.
theramz is offline
Old 04-23-2005, 11:35 AM
Bleach is my Hero
s/cL3.0's Avatar
Cool thx know where I can get some rear brake calipers for cheap?? My right rear piston blew out and it sounds nasty.
s/cL3.0 is offline
Old 04-23-2005, 10:31 PM
theramz's Avatar
That nasty sound means you need new brake pads and at least one rotor. If the caliper isn't leaking, it's probably okay. Changing these parts is easy. Replacing the wheel cylinder is expensive. Rebuilding it is cheaper but you better know how to do it right.
theramz is offline
Old 04-29-2005, 05:52 AM
Bleach is my Hero
s/cL3.0's Avatar
I took the wheel off and the inside pad is stuck closed {on the rotor} I am redoing the rotors calipers, controlarms, and going urathane on saturday any ways I just needed to make sure I bought the right size rotors.I will post pics when I am finished.
s/cL3.0 is offline
Old 04-29-2005, 07:40 AM
Have you done some reading on installing urathane bushings? They aren't easy. Hybridz has a recent post up on it under the wheels/suspension section. Called Suspension Techniques Bushings don't fit!
Bleach is offline
Old 04-29-2005, 07:48 AM
Bleach is my Hero
s/cL3.0's Avatar
Are they anything like the Front?? I was planning on taking them to a machine shop having them pressed out and the new ones pressed in. Since I am doing the bearings to. p.s. buy a carbon hood.
s/cL3.0 is offline
Old 04-29-2005, 08:07 AM
If you're taking it to a machine shop, then I guess that takes the trouble out of it!
P.S. My excuse is no money right now, and he said not to reply if that was your excuse for not putting money down. I've got other things to buy
Bleach is offline
Old 04-29-2005, 08:41 AM
Bleach is my Hero
s/cL3.0's Avatar
Yeah cause I think even in the haynes it says they need to be pressed.. I cant wait
s/cL3.0 is offline
Old 04-30-2005, 10:13 AM
Bleach is my Hero
s/cL3.0's Avatar
So here I am in the middle of things took about an hour by myself, I also broke 4 wrenchs ..I didnt know control arms were gray I also found a brand new set of rear urathane bushings.. {sway bar, and control arm} PM me if you want them 15.00 via paypal and there yours. ps that includes shipping in US 48
Attached Thumbnails Brake question?//-mvc-655s.jpg   Brake question?//-mvc-656s.jpg   Brake question?//-mvc-658s.jpg   Brake question?//-mvc-660s.jpg
s/cL3.0 is offline
Old 04-30-2005, 11:24 PM
Bleach is my Hero
s/cL3.0's Avatar
I am done and it only took 3 hours/?/? Here are the final shots of the completed rear end. What do you think??
Attached Thumbnails Brake question?//-mvc-661s.jpg   Brake question?//-mvc-663s.jpg   Brake question?//-mvc-664s.jpg   Brake question?//-mvc-665s.jpg
s/cL3.0 is offline
Old 04-30-2005, 11:36 PM
lww
Head Muckraker
lww's Avatar
Very NICE! I assume you de-greased the control arms before you painted them?!
Don't freshly painted parts look good?
lww is offline
Old 04-30-2005, 11:47 PM
Bleach is my Hero
s/cL3.0's Avatar
I did my best but even after 1 hour of soaking in degreaser not all of it came off, But it looks alot better and the nu bushings and bearings ride alot smoother.
s/cL3.0 is offline
Old 05-02-2005, 05:34 PM
Very nice! thanks for the awsome pics.
I may be wrong, but are those slotted rotors installed on the wrong side?
Bleach is offline
Old 05-02-2005, 05:43 PM
Bleach is my Hero
s/cL3.0's Avatar
Yeah I hate it when They look like that but either way you put them it is the wrong direction.. I guess thats why they were 114.00 shipped brand new..
s/cL3.0 is offline
Old 05-02-2005, 05:46 PM
no, they shouldn't be like that. They are directional. I can see in your pic that the slots go opposite directions. If you swap sides with the rotors, the rotor will rotate in the opposite direction. As the curved lines come around, the inside meets the pad first. As it passes through the gas is vented outward.
Bleach is offline
Old 05-02-2005, 08:52 PM
Bleach is my Hero
s/cL3.0's Avatar
S.O.A.B . I coulda swor I sawitched them like 5 times before I but them on... ufck, oh well something to do next weekend..
s/cL3.0 is offline
Tree_Stump
12-30-2015 08:16 PM
Wolfsnack
07-12-2014 08:04 PM
corbith
12-10-2012 10:29 AM
Murph Z32
18
02-09-2008 04:11 PM
smokey
02-25-2007 02:17 AM
Quick Reply: Brake question?//
