79 s130 wheels?
Old Oct 8, 2011 | 07:55 PM
Tsuka89's Avatar
79 s130 wheels?
ok so question, trying to do potenza RE-11s on my car also trying to stay within a half inch of the 70series+14in total diameter of 19.3" (my car is lowered-can give ride height from the top of the fenderwell), trying to do xxr 501s in black at 15x8 with +15 offset, Iwas gonna do 205/50-15. What series tires should I go with to keep the 19.3" total diameter? (can be within .5 inches as I said before). Must be (extreme performance summer) sports tires preferably the RE-11s but I am willing to change if it means a better fit.
thanx
Old Oct 8, 2011 | 11:43 PM
Tsuka89's Avatar
I should mention my spring rates are 175 front/200 rear, and I will be autoxing it on the new tires
Old Oct 10, 2011 | 07:28 AM
tirerack has a tire size comparasion thing. just type in your sizes it will tell all
Old Oct 12, 2011 | 12:39 PM
Well for starters the stock tire is 24.7ish. The closest to stock you'll get with RE-11s is 245/40/17 which would fit nicely on a set of RB-R 17x9 -13mm wheels....
225/50/16 are off by just under 1% so you would be fine with those as well
Old Oct 12, 2011 | 12:45 PM
If you have chosen the size of 15x8 then 205/60-15 is stock size
205/55-16 is a bit under and 205/50-15 is way too small.
Tire Size Calculator
No need for +15 if there is an option. even with +0 you will have room in front and room to spare in the back.
Old Oct 13, 2011 | 01:46 PM
Yup and for RE-11 the closest they make them in are listed above....
You'd have to go to a slick or street legal slick to beat the RE-11s for performance....
Old Oct 15, 2011 | 12:15 AM
Tsuka89's Avatar
ok thanks guys, my calculations are off, been awhile since Ive taken a math class
ok update: everything i research says a different thing, why did they make the series a percentage of section width??!!!! why not just measure it directly
when I run the numbers in the calculator I get something different from stock to aftermarket
and if I do the calculation myself I get something different again
confused and frustrated now
RE-11s come in these sizes
195/50R15
205/50R15
205/45R16
205/55R16
225/50R16
205/45R17
205/50R17
215/45R17
225/45R17
235/40R17
235/45R17
245/40R17
245/45R17
255/40R17
willing to run 16 or 17
however as I said I keep getting different comparable sizes for each source
gah
reupdate:
Im looking at the wrong diameter (dammit) sorry for the mess.
Old Oct 15, 2011 | 02:44 AM
Tsuka89's Avatar
lol I forgot to add the other side of the tire sidewall
decided to go 205/55-16 on xxr 501 8" +0 offset rear and +15 front
or RB/RBR 215/45-17 9" 0 offset both possibly
anyway thanks again guys
Old Nov 6, 2011 | 12:39 AM
Tsuka89's Avatar
bumping for curiosity
what is the largest size wheel up to 17" and tire you could run on a 1.5 inch lowered 280zx na- include offset, wheel width, tire section width, and sidewall aspect ratio, thanks guys
Old Nov 7, 2011 | 08:34 PM
You're asking a lot!
Are you talking about hanging your rimz out and stretching tires, hellfa flush, or tucking tires in the fender with or without rolling the inner fender?
You can fit 17x10 +0 with no mods to the car and it'll be pretty close. Unless someone has very specific inner fender specs, your question can not be answered accurately. Instead maybe you can find examples of large wheel and tire setups installed on the 280ZX with pictures of the clearance.
Old Nov 7, 2011 | 10:48 PM
Tsuka89's Avatar
well that does answer my question, and I was only wondering because I heard that the s130 won't take much offset and width without needing to be rolled.
also its a concern of mine since I'll be running some solo 2 events next season and I don't want to be rubbing at all, but I'm in the clear.
I'd prefer not to roll the fender-shoestring budget (and saving for paint)
I'll be stretching only slightly with the setup I have picked out, want it to be practical for bending them curves---
xxr501 16x8 205/55 +15 offset in front and 0 offset in rear
thanks bleach
Old Nov 13, 2011 | 08:46 PM
k1drift's Avatar
im going with diamond racing 15x10 w/4" backspace (rear) and 15x9 w/4" backspace (front), with my car sitting on its nuts... well i just like crazy set ups like that lol tires will be 205/50-15 rear and 195/45-15 front, my fenders are rolled already so im not too worried about that, and if all else fails ill cut the over fenders off and bolt on some zg flares
Old Nov 17, 2011 | 10:21 PM
Tsuka89's Avatar
jesus sounds like a good plan then, I would do ZG flares but I have no moneys and no job ATM
Old Nov 18, 2011 | 02:41 PM
I'm running Yokohama S-Drive 235/45/17 and 255/40/17 with rolled fenders - Yasin is running 255 front and 275 rears... we're both running Rota RB-R 17x9.5 with -19mm offset
Rolling the fenders just takes time - not sure what it has to do with budget unless you can't rent a proper fender roller and need to shell out for one.
Old Dec 4, 2011 | 05:09 PM
87pyro3's Avatar
there metal fenders lol
go to you tube and look up my buddies video ( black240sxdrift ) l title being rolling fenders
just grab a ball bat and a jack and roll them your self for the price of nothing lol or the price of a cheap bat lol
Old Dec 9, 2011 | 08:12 PM
If you like your car get a proper roller....
JacobDrivesA280
Aug 14, 2014 04:38 PM
BlueKitsune
Mar 12, 2013 12:54 PM
DJBRANDER
Apr 6, 2012 03:35 PM
frank280zx
Jun 21, 2007 02:16 AM
LowdedZ
FS: 300ZX (90-96)
Mar 4, 2005 08:16 AM
