S130 Fender Flares
do it like the bob sharp cars, they actually look good and function well. when you do a flare, do you have to modify the inner fenderwell to? our cars always rust and need rebuilding so then would be the time.
I personally still don't even think the 240ZG flares look good on the 240Z. Some of those examples of the 280ZXs that ice showed don't look too bad. The back is a little too much. I'd say a little less flare in the back would look good. I personally don't understand why everyone likes the 240ZG it just looks worse overall and kinda ruins the look. To me I picture it as somewhere in between the 280ZX and the 240Z. It just can't make up its mind, but that's my opinion. I'd say if you have the skill do what that one person did and just extend the fenders and then just fill in the gap.
Can anyone guess what size wheels and tire size are on those ugly Japanese Zs? PLEASE?!?! Because I just got a set of 15" wheels and I need to buy tires for them but Im not sure what size to get since Im not sure how aspect ratio really works. I want to stretch 205s on all 4 corners though since any thicker and I wont be able to drift anymore, since im underpowered! Please can some one help a poor little kid! Im begging you my Z masters! What aspect ratio should I get for the 205s that wont make them as thin as those whack Zs up there? Need...tires...soon....oh the wheels are 15x8!
Thanks a bunch bro! Im looking into BF G-Force Sports up front, and with the 60 or 65 sidewall my wheels wont look tiny like those Zs right? But will I have as much rubber as the stock 205/70R14s? Do you think you can maybe photoshop how 205/60R15 would look? Please. Cause I also want to eliminate wheel well (Tokicos 1inch drop only do so much!) No problem if u cant im asking for too much anyway! also I was wondering if stretching the tire on a wide rim would make the tire height shorter right? Thanks again!
Ok well I went ahead and made a sort of side by side thing here but you get the idea. My size is in the middle, very low side-wall and large fender gap. The left is the factory 205/70/14 and the right is the size I suggested...if you notice the 15 inch 215 is near identical to the factory outside diameter and the width is only slightly wider...like I said 10mm. The side wall will be shorter and should be stiffer, in my oppinion it should break traction easier then the taller wall as it should not flex as much when sliding. Again just my oppinion and it makes sense to me... it is the size I will be going with but not for the drifting reason, I just want my spedo to be correct with my 15" rims. Hey I could be wrong and they may grip more because of a larger contact patch on the road either way you may want to use spare, bald or old tires for drifting so your new tires will last.
Attachment 4549
Attachment 4549
Man I wish I could afford new tires cause you could have mine for the price of shipping...205/50/15 on a 7 inch wide rim...you can see my gap with stock suspension. They have 85%+ tread on them or more.
Attachment 4550
Attachment 4550
mmm 205/50R15 look pretty nice too and still have some nice amount of sidewall! Maybe Ill go with that aspect ratio and stretching them 1" father on the 8inch should get me that look im looking for! Thanks alot, Thxone! Appreciate the help!
Ah, so I was going through a VB catalogue (or Black Dragon, w/e) and what do I see? FENDER FLARES!!! I didnt have time to scan the page but if anyone has the 2005 fall edition Z.46 (it has a red S130's headlight as the cover!) then go to page 45 and look to the bottom right...ahh
Fender Flares
DarrellBuddy321
Feb 27, 2014 05:45 PM
