Racing Seats (Please Help)
Old Aug 20, 2006 | 09:29 PM
SoCal-s130's Avatar
Returning Bleach Groupie
Alright, so I just figured out why s130's are hard to put aftermarket seats in them...Well, I was wondering if anyone else here put some after market seats in their zx, if so I need info on what you did to the brackets...I appreciate the help.
Old Aug 20, 2006 | 09:31 PM
jfairladyz's Avatar
I know 81black did, but he involuntarily left the site Search around and you'll find his thread where he put them in. I think he used some seats he got at a local parts store. There are quite a few threads on modifying seat brackets to make different seats fit.
Old Aug 20, 2006 | 09:34 PM
SoCal-s130's Avatar
The "universal" brackets that came with the seats are automatically out of the question just because of the set up in the s130...So I have to find a way to get everything flush on top of the stock brackets because the seats are flat on the bottom. But I will give the site a search and see if I can find something.
Old Aug 20, 2006 | 09:57 PM
SoCal-s130's Avatar
Cant find anything.
Old Aug 20, 2006 | 10:24 PM
SoCal-s130's Avatar
Anyone that can help me?
Old Aug 20, 2006 | 10:25 PM
91Zman's Avatar
Opinionated
i have Forza's in my Z
Old Aug 21, 2006 | 12:19 AM
jfairladyz's Avatar
https://www.zdriver.com/forums/showt...ighlight=seats
Old Aug 21, 2006 | 05:00 AM
260DET's Avatar
Have not put mine in yet but it does not look difficult. Main thing is that the X chassis member that the front of the seat will bolt to is nice and low, so no headroom problems. Matter of putting the seat in where you want it and measuring up any brackets that have to be made.
With the S30 that member was higher and had to be cut away, which then required the fabrication of a bolt in reinforcement piece.
Old Aug 21, 2006 | 08:33 AM
lww's Avatar
lww
Head Muckraker
You generally have to fabricate your own brackets. I have Scat ProCar seats in my 240z and Corbeau A4's in my 280ZX. Both required custom brackets fabricated and with the ZX you'll have to re-mount your seat belt receiver buckle if you don't re-use your stock sliders.
I would recommend re-using your stock sliders and making new brackets for your stock sliders. This will let you keep your stock seat belt receiver buckle in the same place.
I recommend you make a template of your seat base and the factory floor board mount points, overlap the two and see how best to make a new bracket to mate them together.
Also, make sure you use hardened steel for your brackets. Those brackets are what hold the seat to the car in an accident. Using cheap steel brackets from Home Depot will shear off without hesitation in a real accident.
Old Aug 22, 2006 | 04:12 PM
KTM200-280zxt's Avatar
I had to fabricate my own like LLW said. Man was thata bitch. Except I used the universal sliders that came with mine. Theres not really a guide on how to put all aftermarket seats in a 280zx. You just need to spend some time looking at everything and make up some nice brackets.
Old Sep 7, 2006 | 06:51 PM
Z Car Barbie's Avatar
User Friendly
I simply removed the seat rails from my original 280ZX seats and attached them to the new seats.
Old Sep 7, 2006 | 06:53 PM
SoCal-s130's Avatar
Heres what happened, I had everything going great and then I go to bolt them in and the seat made the brackets too wide. So I am going to have to get a piece of metal and make like a sideways bracket with two holes in it for them to fit.
Old Sep 7, 2006 | 07:35 PM
lww's Avatar
lww
Head Muckraker
I would do more than just make an L bracket. Get a 4' length of 1" wide hardened steel, cut it to the correct width/length, weld it to the original floor mounts where the new steel will extend out to where the bolts come down from the new seat, drill holes in it where your slider's bolts hit, put your seats in and bolt 'em down.
The seat is the only thing that holds onto you in the event of a crash and if they aren't properly secured to the floor of the car, they'll just rip right out and PUSH you into the windshield. Even if your seat belt is on, in our cars, it's attached to the seat rails!
Old Sep 7, 2006 | 08:27 PM
User Friendly
If you put your old seat rails on the new seats, then the bolt pattern should line up unless the new seat doesn't have clearance for the slight humps in the frame. Have you tried doing that?
Old Sep 7, 2006 | 08:47 PM
SoCal-s130's Avatar
Oh im definately not doing anything cheap.
I did use the stock ones, they line up good except for width wise.
Old Sep 7, 2006 | 09:59 PM
User Friendly
Whatcha mean "width wise"? The seats are too wide or the seat rails don't line up? Got pix to show us the problem?
Old Sep 7, 2006 | 10:09 PM
SoCal-s130's Avatar
It spreads the brackets out too wide.
Old Sep 7, 2006 | 10:19 PM
User Friendly
Using the stock rails? Sorry, I don't understand.
Old Sep 7, 2006 | 10:33 PM
SoCal-s130's Avatar
Yeah, stock rails on new seats = too wide to mount.
Old Sep 7, 2006 | 10:52 PM
User Friendly
Sorry, I still don't understand. The stock rails line up to the existing mounting holes. What exactly is too wide - the stock rails mounting to the new seats or the rails mounting into the mounting holes in the floor?
Old Sep 7, 2006 | 11:16 PM
SoCal-s130's Avatar
The rails mounting into the mounting holes in the floor.
Old Sep 7, 2006 | 11:22 PM
User Friendly
Do you have any pix to show us? If you put the OEM rails on the new seats, the mounts should bolt right in. How far is it off, by a couple of centimeters?
Old Sep 7, 2006 | 11:49 PM
SoCal-s130's Avatar
If I line one side up then the other side is off about an 1 1/2 inch.
Old Sep 8, 2006 | 12:33 AM
User Friendly
I had the same problem because the rails were slightly off ... kind of warped from the rail conversion. I bolted the right front mount, then the left back mount (don't tighten them - just lightly screw them until they're somewhat secured). I then bolted the other front mount, and played h*** trying to get the last mount to line up. Once you get them in, then start tightening. It can be a pita, but it sounds like you're having problems with that hump, which is what causes the offset.
Old Sep 8, 2006 | 07:19 AM
i bought apc racing seats, with anyrails, they sit too high for my 6'0" frame. so i bolted them directly down using cut up pices of my spare seat rails, i got no sliders and it fits great, really hard to get the back bolts tho, i need double jointed wrists
ricksilvia
May 11, 2014 10:12 AM
danogeno
17
Dec 7, 2007 12:31 AM
LS2TTZ
May 14, 2006 01:25 PM
Geeyawn
Mar 27, 2006 06:27 PM
Bryan_280zx
Mar 21, 2006 04:19 AM
