Newbie - Looking for GOOD wiring diagrams
Anybody know where to find comprehensive diagrams that would cover an "83 ZX 2+2. I'm trying to install some new tunes but want to avoid the major work of installing new wiring and making it look factory
. A source for connectors for the factory plugs would be best
wireing up a new streo isnt that hard to do. all you really need is a light tester. you can buy aftermarket wire connectors that hold up to 8 wires. for your stereo all youll need to find is the constant power source, ign. power source. its the wire that turns on when your put your key to the acc or on posistion. then you have your ground. always wire the ground to the chassie. its better to do it that way so you dont get the engine wining noise everytime you gass it. then you have your illunination lite. use the lite tester to find out which wire turns on when you turn on your headlights. the you have your power antenna wire. and the rest are just speaker wires. if thats too confusing for you just get the haynes manual. they have a wire diagram in the back of the book that can help you..
Thanks for the info. I used my multi-meter and got everything installed. Is there any aftermarket mfg's that offer custom enclosure for the doors/kickpanels? I also need some tan interior panels for an '83 2+2 if anyone is selling.
