big phat 7 inch TACH...
Ok well i have my friend adam lucas hear in town that has bought a " big tach " and he was having problems hooking it up.. So i had to show him about the wires in the back of the tach for 4 ,6 , 8 cyl... so i choose 6 cyl .. for him then the instructions say to hook it up to your distributor ? so i would have to splice into the harness conneting into the bottom of the turbo dissy am i right ? i know NISMOPICK would know and answer this question.. but what color wires to what ?
Are you hooking it up to a 280zx? If so I belive you can hook it up to the ( - ) negative of the coil...what is it...Green, Red, Black, and White wires on the new tach? Either way, double check, I could be a little off on the connection.
You'll have power and ground for the tach. That allows the thing to even turn on and work. The signal wire goes to - on the coil. Then the white wire I think is for the backlight.
A 280ZX already has a 6" tach, I dont' see the need for another one. If you want to intimidate other drivers then paint a rising sun on your hood.
Rrassi300zx
Feb 12, 2013 08:29 PM
TEDS280Z
Jul 5, 2005 07:25 PM
