big phat 7 inch TACH...
Old Sep 21, 2006 | 06:12 PM
nismo619's Avatar
Ok well i have my friend adam lucas hear in town that has bought a " big tach " and he was having problems hooking it up.. So i had to show him about the wires in the back of the tach for 4 ,6 , 8 cyl... so i choose 6 cyl .. for him then the instructions say to hook it up to your distributor ? so i would have to splice into the harness conneting into the bottom of the turbo dissy am i right ? i know NISMOPICK would know and answer this question.. but what color wires to what ?
Old Sep 21, 2006 | 06:21 PM
thxone's Avatar
Are you hooking it up to a 280zx? If so I belive you can hook it up to the ( - ) negative of the coil...what is it...Green, Red, Black, and White wires on the new tach? Either way, double check, I could be a little off on the connection.
Old Sep 21, 2006 | 06:55 PM
jfairladyz's Avatar
^ correct. The misc. wires are for illumination. If it's anything like an Autometer tach then one of the wires wont get used if it's going in the Z.
Old Sep 26, 2006 | 08:43 AM
You'll have power and ground for the tach. That allows the thing to even turn on and work. The signal wire goes to - on the coil. Then the white wire I think is for the backlight.
A 280ZX already has a 6" tach, I dont' see the need for another one. If you want to intimidate other drivers then paint a rising sun on your hood.
Old Sep 26, 2006 | 11:40 AM
apollo's Avatar
Pro Pumpkin Carver
Just do a reverse burn out then jam it in 1st and call it a day
Rrassi300zx
Feb 12, 2013 08:29 PM
TEDS280Z
Jul 5, 2005 07:25 PM
jmalone
Sep 23, 2004 01:36 PM
uc1tufz
Oct 2, 2002 12:05 AM
RGman
May 23, 2002 05:40 PM
