**T-top LEAK DRIVER DOOR WINDOW LEAK***
Old 12-24-2008, 02:24 PM
Joose Bocks
d33zdrama's Avatar
Angry **T-top LEAK DRIVER DOOR WINDOW LEAK***
Wat can i do? my driver seat gets wet the window leaks and the t-tops leak its a 81 280zx w/5spd turbo swap.
d33zdrama is offline
Old 12-24-2008, 02:33 PM
I'm a Registered User!
SpeciallySpiked's Avatar
In what location along the t-top is it leaking? Is it where the t-top, window, and body meet?
It can be any number of things from the rubber not sealing correctly to the window and the t-top not lining up correctly.
If it is the rubber's fault, I suggest using Vaso-line to make a better seal.
If it is the window's fault, look into if the window is closing all the way/where exactly it is not fitting up correctly.
SpeciallySpiked is offline
Old 12-24-2008, 03:05 PM
Haterade by da gallon!
280zx2by2's Avatar
there are several ways to fix this but do you just want a link to replacemant seals? http://www.thezstore.com/page/TZS/CTGY/SWR02E there you go
but i fixed alot of my leaks with RTV/silicone and rubber stick-on door spacers/seals
btw nice sounding car, like to see some pics, and welcome to ZDriver
280zx2by2 is offline
Old 12-24-2008, 05:54 PM
Joose Bocks
d33zdrama's Avatar
yah i visted the link those things are expensive ill put sum pics up as soon as this snow melts.we got alot of it.i think ill go with the silicone thanx guys.
Old 12-28-2008, 10:49 AM
xenonxiii's Avatar
Guys,
I am having the Z31 T top seals reproduced by Metro Moulded Parts, Inc., If there is Interest and some one is willing to donate a set of seals, I will gladly send them in as well for molds to be made.
xenonxiii is offline
Old 01-27-2009, 11:08 AM
BrianFahey's Avatar
I'm not familiar with Z cars (yet), but in my (torrid) past I came across rubber drain holes/lines in the vallys of the seal that were plugged with dirt and debries. The water welled up and had no where to go and simply overflowed the seal dam. If that's the case, find out where they drain out to and blow some compressed air backwards (from the drain outlet side). Don't put in so much pressure it inflates the hose and blows it off the nipple or worse- bursts the hose deep inside of the body. After the air comes out then wash the drain out and run some plastic wire down to help clear it out. If there isn't a drain then sorry for interrupting . ;-)
BrianFahey is offline
Old 01-27-2009, 01:21 PM
In my past car, I had a theory that the outter edge of the t-top itself was the problem. Water may be leaking into the handle part and the comming out near the corner of the t-top. This appears to be through the seal but may not be.
I never got around to fixing it before I sold that car.
I was going to disasemble the handle portion and then put some black silicone along all the inside edges while putting it back together. Then a small bead on top where the glass meets the metal.
Bleach is offline
Old 03-16-2009, 08:00 PM
runningjalapeno's Avatar
vaseline helps for a while but they will start to leak again i've had this problem for several years now, I was told by the bodyshop the seals had shrunk and they needed to be replaced . I also adjusted the window and it helped for a while.
runningjalapeno is offline
Old 03-18-2009, 10:20 AM
vrocious's Avatar
my trick was get the silicone and run a bead of it along the inside of the targa panel but not on the glass, where the panel contacts the rubber. hey presto no more leaks. but after about 6 moths it will squish down a bit but then just repeat. i did it both sides on both panels and i know when i get a few drips after a wash its time to do it again
vrocious is offline
Old 04-08-2009, 10:03 AM
280zdude's Avatar
Careful with petroleum jelly. That can seriously deteriorate (sp) the rubber material.
280zdude is offline
Old 02-25-2012, 04:54 PM
gordo USA's Avatar
My 83 t tops also leak onto the drivers seat and now the passenger seat as well. Thought I had it fixed for awhile using silicon but apparently that dried out also. Need the weatherstriping to fit on the body. Repair shop said they are shrunk and need replacing.
NEED to find t-top seals for a 83 280ZX coupe.
Anyone know where to locate these seals? Please let me know before it rains again !!!!
gordo USA is offline
Old 02-26-2012, 01:00 PM
^Try www.Blackdragonauto.com I believe their seals are pretty reasonably priced. I thought about getting those in the future for my '82 T-top.
Here you go.
http://www.blackdragonauto.com/icata...l.aspx?page=15
WildmaN is offline
Old 02-29-2012, 08:08 AM
gordo USA's Avatar
Blackdragon has the RH side for a 2+2, I have a coupe.
But is a good price. lol.
Thanks for the effort.
Old 03-01-2012, 10:29 PM
Those seals are the little itty bitty cheap one that goes on the actual t-top. You need the other seal as well that goes up the window around the t-top and down the side. They run from $300-500 a side.... that would be worth reproducing if they were reasonably priced....
FricFrac is offline
Old 03-03-2012, 05:15 PM
tennhogfan's Avatar
FWIW If I open the doors before rolling up the windows it allows another 1/16" or so more travel allowing a better seal at the ttop.
For me the difference between a damp or dry seat.
tennhogfan is offline
Mike Phillips
10-01-2021 12:34 PM
DeathByNissan55
12-13-2020 03:42 AM
Aeleven
08-19-2015 10:09 AM
theUniverse
08-23-2012 07:01 PM
chargers21
07-30-2008 06:14 PM
Quick Reply: **T-top LEAK DRIVER DOOR WINDOW LEAK***
