240Z-280ZXT S30-S130 Tech Tips For 70-83 S30's & S130's
280ZX - both power windows stopped working at the same time
Old Jan 26, 2009 | 06:25 PM
If both your power window switches lose power it could be the power window breaker that has failed.
It is bolted behind the metal just above the fuse panel. Remove the plastic trim around the fuses, the under dash panel, and then unbolt the wiring harness plugs from the car. You can then unbolt the bracket just above the fuses and squeeze the fan timer and window breaker out and around.
I replaced mine with a used one.
Once working, the windows were slow and showed signs of dragging. They were probably tight from not being used often. I took off both door panels and lubricated the power window slides inside the door.
linkovich
Dec 31, 2014 01:47 PM
gt46l
Oct 17, 2014 06:51 AM
1980datsunz
Aug 17, 2013 03:46 PM
Turbo86
May 23, 2006 03:26 PM
