Hi guys, I have two questions. First I just wanted to verify if I could use an analog speedo cluster wiring harness from the years 81-82 zx and use it on a 79 analog speedometer cluster (130mph)....I have a turbo zx, do I need to get a harness from another turbo model or would the NA harness still work with the three small gauges equipped with the turbo and oil temp gauge??? I'm pretty sure I could but I just want to make sure as I'm not sure if I HAD to get a harness from another turbo zx. My other question is...how do I pull the needles off on the speedo, tach, temp, gas gauges, etc? The reason I need to take them off is because I'm going to be putting on white overlays and I can't put them on unless I pull the needles off (I also wanted to paint them red.) I tried pulling them but I was afraid they would break. As always, thanks for the help
ratedZ
ratedZ
Registered Zee Racer
They are very easy to break, but they do pull off. Not sure on the wiring harness for the analog gauges. My car is analog. I used a 79 speedometer face and had my unit recalibrated for the new face.
Darrel
82zxt
Darrel
82zxt
