What's my speed?
Old Sep 20, 2002 | 11:35 PM
Re: What's my speed?
On a dyno, it tells you how fast you are going. My 82 280zx was running at 100mph at 5,300 rpm in 4th gear. When you shift to 5th it drops to about 4 grand. So you were going 100-110 mph. Wohoo!
Old Sep 23, 2002 | 02:14 PM
Actually, at 4000 rpm in 5th you'd be at 100mph.
At 5700 in 5th you'd be at 145mph. That's higher than the 280zx's top speed rating. I don't think you have enough power to go that fast.... or you must of found a very long downhill slope!
Mine stops at about 4500 in 5th gear, but the freeway isn't all that level either.
Old Sep 24, 2002 | 07:30 AM
Spudz's Avatar
Hey Guys,
Most of your experiences of high MPH are based on your
factory tachs and speedometers. It doesn't take into consideration equipment error , tires size or other factors.
I would think a ZX is good for somewhere in the 125 MPH
plus range and a bit less for the 240. Thats just from the info
I have seen from actual track tests.
Mike
Old Sep 24, 2002 | 10:12 AM
ShaneZ's profile says that his Z is running 205/50/15 tires. That is undersize. That is like swapping from a 3.5 to a 3.9 rear or 3.9 to 4.11
Plus, his 280z 5-speed has a lower (more torque) 5th gear than the 280ZX. The speed rating I said was if you had the 81-83 non-turbo 5-speed (highest 5th gear possible) and a 3.9:1 rear end running stock tire size of 205/60/15. (or 195/70/14)
With his tire size and going 5700rpm he would only be at 127mph with a 3.54 rear or 116mph with a 3.9 rear.
:-D
Old Sep 24, 2002 | 04:15 PM
Spudz's Avatar
Hey ZR8ED,
How is the new motor coming along ?? You going to get it in this
winter ??
Mike
Old Sep 30, 2002 | 08:30 PM
duckyz's Avatar
I have an '83 ZX na. When it was running top notch (stock), I asked my brother 'n law to call hit trooper friends and tell them we want to blow out our cars. He has an '86 Ferrari Mondial. To make a long story shorter, he started pulling away from me and I was running close to 6k ( I have a digital dash too...), so I flashed my lights at him. When it all was over, he told me that we were going 130 when I hit my lights.
thetorp
May 4, 2016 05:39 PM
JBenbenek
Jan 17, 2006 04:47 PM
bluesman1958
Apr 15, 2004 03:31 PM
normanc
Sep 16, 2002 04:19 PM
trunkolo26
Sep 8, 2002 05:50 PM
