umm...
Old May 10, 2006 | 09:52 PM
FairladyZS30's Avatar
umm...
i wanna do a l28et swap in my 240z....i wanna know everything that im going to need...and will a wiring harnes from a 280zx n/a work for thir swap?
Old May 10, 2006 | 10:04 PM
icice9's Avatar
Super Siver & Black Stud
why not do the l28 tubo swap.. bout the same amount of work but with more HP gain...
Old May 10, 2006 | 10:19 PM
jfairladyz's Avatar
no, the wiring harness from the non turbo cars will not work with the turbo motor. The ECU side is completely different and the turbo and non turbo motors dont share very many parts other than some of the sensors.
If you wanna be on the safe side then grab EVERYTHING in the engine compartment, including wiring that is in someway related to the engine. That will ensure you get everything. It's much easier if you have an entire turbo car to pick from. You'll also want to grab the fuel pump modulator from inside the cabin (though this can be bypassed, as I did it). And dont forget to grab the EFI relay and wiring from over behind the battery as well as the fuse links/box.
Old May 10, 2006 | 10:22 PM
icice9's Avatar
thats not what i was trying to say,, hes gonna do a complete engine and wireharness swap.. what i meant was why not do the trubo swap instead...
Old May 10, 2006 | 10:24 PM
jfairladyz's Avatar
I was saying no to his question, not what you said Ice
I thought he was swapping in an L28ET but was also asking if the NA harness was compatible I guess we'll have to let him clear that up.
Old May 11, 2006 | 10:22 AM
sounds overwhelming, explain ice
Old May 11, 2006 | 10:31 AM
There's about 4.2 billion web pages (ok... a lil over exagerated) that talk about doing the L28ET swap. It's not hard, I've done it. It's just time consuming.
The guys on hybridz have done tons of write ups on the swap.... (Not trying to be an ***, just don't feel like typing a book that someone has already written).
http://forums.hybridz.org/search.php?searchid=417555
Old May 11, 2006 | 10:43 AM
skittle's Avatar
Taste My Rainbow
Hey Nismo Don't We Get This Question At Least Once A Week On Here?
Old May 11, 2006 | 11:00 AM
At least!
Old May 14, 2006 | 08:15 AM
i got my z!now i need to get sheet metal so i can cover that hole in the back
Old May 14, 2006 | 08:48 AM
mikedick6969's Avatar
That one looks like a bit more work than the one I just got. But good luck with that.
Old May 14, 2006 | 10:37 AM
jfairladyz's Avatar
Bondo is usually a bad sign. Especially raw bondo. But have fun with your project.
Old May 14, 2006 | 08:22 PM
noo it wasnt in a accident...its boddy filler becuase the other owner wanted to wake out the holes that the bumper left...basically...he didnt want a rear bumper..you guys should know that look
Old May 14, 2006 | 10:01 PM
yup...my dashboard that is in a very good shape which came in the car
Old May 15, 2006 | 07:51 AM
ASA240z's Avatar
ダットサンマニアック
https://www.zdriver.com/forums/search.php
This should help...
