Turbo Squeel?
Re: Turbo Squeel?
Check your belts. They might be loose or going bad. Easy to replace and it would also be a good time to check the condition of your water pump while you have the belts off and you're in that area of the engine bay.
82ZXT
71 510 autocross & 71 510 daily driver
82ZXT
Guest
Posts: n/a
Re: Turbo Squeel?
J.V. Try this. If it is a belt squealing, buy some belt dressing and spray it on the belts, or just use some WD40. Old belts + rusty pulley = squealing belts. If it is the turbo, at least you looked at the belts and may see a future problem-maker. Make sure the turbo is getting oil, an oil change won't hurt.
BTW. The 83ZXT I got from you in Sept is on blocks, the inner fender well has been replaced, and I'm making the floorboards this weekend. Z'ya!
Michael M.
Michael M.
Melspace02
FS: 300ZX (84-89)
Sep 5, 2012 06:28 PM
johnsonsz31tt
May 7, 2008 07:27 PM
thunderz
Feb 12, 2006 06:46 PM
