Turbo conversion?
Old Jul 12, 2002 | 03:53 AM
Fredrik's Avatar
Re: Turbo conversion?
It is probably a good idea to install a fuel pressure regulator that boost the fuel pressure when the turbo builds up pressure. Another way is to install a turbo fueller. You can find a turbo fueller at www.perfectpower.com
Old Jul 12, 2002 | 07:39 AM
Well, if you actually want to use the turbo, you need to put in the 280zx turbo fuel rail with injectors, and also use the computer and wiring from the turbo.
Also, the turbo block has pistons with thicker rings. The block itself is the same, but your rings may wear a little faster using a non-turbo piston setup.
cerealkilla
Jan 11, 2004 03:27 PM
Shameless
Oct 23, 2003 06:33 AM
79GS130ZL
Oct 11, 2003 08:36 AM
79GS130ZL
Aug 30, 2003 12:24 PM
280 drooler
Jun 18, 2003 10:15 AM
