top speed of my 78 280z
Re: top speed of my 78 280z
Safe top speed? Depends on your aerodynamics. You may experience front end lift at over 120mph. The rear end of the Z is also very poorly designed, and will create turbulence at high speeds behind hte hatch. If you already have a NON FLEXIBLE airdam and a functional spoiler in the rear, you have better chances of not flipping your car
With a stock engine and a 4 or 5-speed, your top speed IS 120mph. (maybe 125 on a really smooth road)
Same all the way up through 1983. 125 or so... I'm not sure if the 300ZX brought on a faster top speed. Probably a little. The turbo models though, had more power and higher gearing so I'm sure their top speed is higher. I think the 280ZX turbo is 140?? right?
So the 6-speed 350Z is about 180? :-D
Guest
Posts: n/a
I went to confirm my earlier post. I got my 78 upto 130@5000rpm. On the flat ground this time. This one has airdam and spoiler : ) Not stock either. Well, it's posible to hit 130, the aero kit really work too. So the top speed would be around there 5000rpm in 5th gear.
Pzary3233
Mar 24, 2011 10:52 AM
