Struts: what's best to remove gland nut?
Old 01-20-2012, 02:01 PM
turbopuppy's Avatar
Aside from a pipe wrench, what works best to remove the big gland packing nut from the strut? The FSM says kent-moore J 26803, but that tool is proving impossible to locate. Anybody fabricate something for this job?
turbopuppy is offline
Old 01-20-2012, 04:39 PM
Lurker
noboosts130's Avatar
I've always used a pipe wrench.
noboosts130 is offline
Old 01-20-2012, 05:12 PM
Or a big pair of channel locks, or a big wrench.
hoov100 is offline
Old 01-22-2012, 10:07 AM
turbopuppy's Avatar
Hmmm. Yeah the pipe wrench first. It would work great to remove the gland nut. It's not suitable to torque down the new one with the strut cartridge update. I can't imagine how to hook up a torque wrench to a pair of channel locks either. I considered a big wrench but the cost is prohibitive. There are two sizes: 55mm to remove the nut and 51mm to install the new one. The outer casing is 50mm and the pipe wrench is sure to marr the tube. A 24" adjustable has the capacity and torque really isn't that big a deal because the specs are quite a wide range. Like 51-94 ft-lbs. But there are pin wrenches that you can use with torque wrenches and drivers. That may be what I need.
But, what the question was if anybody knew where a correct tool can be found? Or if someone made one I'd like to hear about it. I saw one where a guy pressed two tapered pins into a pair of channel locks.
Old 01-22-2012, 01:01 PM
Go to local Home Depot / Hardware store, buy correct wrench, use, return to store as you "got the wrong size".
I used a big set of vice grips. Worked fine on the removal and install... no problems torquing it down.
Ever tried NISSAN? Look up the tool part# in the FSM and call Nissan.
If you want a NISSAN part / tool, you go to NISSAN.
NismoPick is offline
Old 01-29-2012, 11:57 AM
turbopuppy's Avatar
Vice grips looked like the best way to go. I found some large jaw pipe locking pliers and added the torque bar to them. I bolted a lever to the wheel's lug stud and it came right off without any mess or damage. Nice Call!
Old 06-04-2012, 01:27 PM
chaztg's Avatar
gland nut removal
If big channel locks don't budge it, use a hammer & chisel to persuade it to rotate...you get a new one anyway with your replacement strut insert.
chaztg is offline
LemonHead
01-10-2012 07:46 PM
supalax15
05-22-2011 03:12 PM
8ty7z
07-27-2010 12:14 AM
duowing
12-27-2007 12:25 PM
RodMoyes
06-26-2006 01:33 AM
Quick Reply: Struts: what's best to remove gland nut?
