Starter wiring?
Old Nov 13, 2002 | 02:42 AM
Fredrik's Avatar
Re: Starter wiring?
Try to hit the solenoid with a hammer while turning your ignition key, it helps if its stuck. To test the starter you can connect it directly to the battery and see if it works.
Old Nov 13, 2002 | 07:44 AM
Re: Starter wiring?
Ya, with your key in the "on" position, run a small wire from the positive on the battery and touch the little wire tab on the back/top side of the starter solinoid. The engine should start cranking right then. If the solinoid pops out each time, but doesn't crank then your starter itself is fried.
Old Nov 14, 2002 | 01:12 AM
Fredrik's Avatar
Re: Starter wiring?
Make sure it´s grounded, if it is you probably need a new starter.
Nick Napala
FS: 300ZX (90-96)
Feb 7, 2014 01:55 AM
El_Colombiano
Jan 18, 2013 03:36 PM
sidneyam
Apr 7, 2011 04:26 PM
vvillium3
Aug 21, 2005 09:06 AM
AlongCamePeter
Sep 12, 2004 06:20 PM
