spindle pin tapered lock bolt
Old May 27, 2004 | 08:19 PM
theramz's Avatar
I have a present for you...
Originally Posted by kivadog
When Replacing The Spindle Pin Tapered Lock Bolt I Tightened The Nut And The Lock Bolt Was Pulled About 1/4 Inch Into The Casting, The Ones That I Had Removed Were Flush With The Top. Am I Doing Something Wrong Or Is This Ok? I Am Lining Up The Flat On The Spindle Pin With The Flat On The Tapered Lock Bolt.
Does Anyone Have Any Good Advice For Reinstalling The Tapered Lock Bolt?
Thanks
As the pins age they become worn on the flats. when you reinstall them they simply go deeper. You should replace the tatered lock bolt. You can get them from MSA for $11.11 each.
BozZ
Oct 18, 2012 04:22 PM
BRAAP
Apr 9, 2010 01:04 PM
OlderThanMe
Dec 11, 2004 06:11 AM
Darrel
Apr 24, 2003 07:41 PM
Darrel
Apr 12, 2003 07:45 PM
