Rough operation?
Old Apr 30, 2003 | 12:50 PM
zpeedracer25's Avatar
Sounds like you have either an ignition miss or bad injector. You need to do some trouble shooting to figure out what cylinder(s) are to blame. Let it idle, get a spark plug boot puller and gently pull off the number one wire slightly from the plug and see if the miss gets worse or is unchanged. Replace plug wire on plug and move to next cylinder. Do this to all cylinders to narrow down which cylinders are missing. This way you can make sure there is spark getting to these cylinders as well. When you get it narrowed down by cylinder, pull the plug and inspect it. If its wet and black, good sign the plug is bad. If its dry as a bone, probably not getting any fuel. Also a good idea to have the compression of the missing cylinder(s) checked when you've got it narrowed down to see if its a miss due to low compression. Hope this helps! Good luck.
ryencoke
FS: 300ZX (90-96)
May 18, 2012 11:45 AM
SoCal-s130
May 16, 2007 01:45 PM
OMGWTFBBQ
Feb 1, 2007 08:53 PM
mattduskater
Jun 2, 2006 12:01 PM
Mousier158
Sep 8, 2005 07:35 AM
