Purchasing 1975 280z please help (pics)
Old Jan 24, 2013 | 10:28 PM
RoCa's Avatar
Looking forward on buying this Z but would like to know if I'm getting a good price. Can someone please let me know if this Z is a decent price at 2K?
Pros:
-1975
-Running
-Not an eyesore
-new head gasket
-new water pump
-new timing chain
-new muffler
-new calipers
-new brake pads
-"turned the rotors"
-few things in the interior
-has replacement dash (no cracks)
-rollbars installed
-tags are good till' dec
cons
-Stutters at about 3000-4000 rpm (mechanic said Air Flow Meter needs to be replaced)
-Rust, dents and other body damage (as shown on pics)
-original head gasket was blown, fixed. heads were warped, fixed.
-fuel gage does not work
-missing one wiper
-one turn signal not working
-small tears in seat
-ac does not work
-no spare tire
-driver side needs weather stripping
-passenger door closes and latches but has half inch gap
-rollbars installed?
Please let me know your opinion. Thanks in advance!
Old Jan 27, 2013 | 09:49 PM
theramz's Avatar
I have a present for you...
It has through rust in areas that don't normally rust that bad. Check the frame rails, hatch area and under the battery tray. Your cons don't list that it has major rust, needs body work and paint. If you can't get it for $500 and fix it yourself, pass!
Old Jan 27, 2013 | 09:58 PM
evandubya's Avatar
Primer Grey FTW!
Looks like a lot of Bondo, and wavy paint, from having to fix bad repairs on the ones I own, I'd run away from it!!!
Old Jan 28, 2013 | 12:19 AM
Homeboyx's Avatar
Run forest run!
AVCM
Apr 20, 2006 01:23 PM
datsunfreak
Feb 12, 2004 03:59 PM
glyph78
Mar 26, 2003 11:23 AM
SunTadZ
Feb 14, 2002 02:15 PM
