novice needs help 240sx throttle body
Old Aug 12, 2002 | 12:16 PM
Re: novice needs help 240sx throttle body
I can tell you that the fast idle circuit does not connect. Also, you'll have a lot more toe-in throttle response which can get very annoying on a daily driver. Trying to slowly accellerate and decelerate in traffic is not fun. The throttle has more tendency to stick and a slight movement jerks the Z forward and jerks back when backing off the throttle. At higher speeds you don't have that problem. I have one on my 280zx and I'm taking it off and putting the stock throttle body on! I've actually had it on for a couple years and I have gotten used to driving with it, but I remember how much easier it was with a smaller throttle body. And cold-starts suck. I would recommend keeping the stock size throttle body and instead opening up your air flow meter.
Do the "280ZX Turbo AFM housing" with non-turbo AFM electronics. Tune it to work with your engine. Even then, the inside diameter of the turbo AFM is hardly as big as the stock size of your non-turbo throttle body. :-) so they match up good and should give you some more power while maintaining a good even throttle response.
MMiskoe
FS: 300ZX (84-89)
Dec 5, 2014 02:44 PM
zlaxbro
Feb 1, 2013 03:11 AM
lukypetr
Apr 10, 2009 04:47 PM
KTM200-280zxt
Jul 18, 2006 10:12 PM
duckyz
May 28, 2003 09:53 PM
