Need More Power/speed!!!
Old Jul 24, 2002 | 09:24 AM
Re: Need More Power/speed!!!
If you are putting on a larger throttle and ported intake, do the turbo AFM upgrade. Buy a Air Flow Meter from a 280zx turbo. Take out the inside electric components. Put the AFM components from a non-turbo AFM inside the housing of the Turbo Meter. Then you'll have to adjust it untill your car runs at the correct richness. This will open up the bottleneck in your intake. Of course, use a cone K&N air filter on the front of your induction tube.
Shave the head slightly on your Z, and advance the cam sprocket one point to correct the slack in the timing chain. Raising the compression helps with torque as well as makes way for a performance cam and new followers.
thetorp
May 4, 2016 05:39 PM
audiofreak97
Nov 19, 2010 06:20 AM
dukesplace
Oct 8, 2008 09:45 PM
JBenbenek
Jan 17, 2006 04:47 PM
bluesman1958
Apr 15, 2004 03:31 PM
