Need More Power/speed!!!
Guest
Posts: n/a
What can i do? let me know i ham doing intake and exhaust just to open it up then 240 throttle body and ported intake manifold... let me know what else i can do i have a 79 280 zx. will the electric fan help free up some power?
thanks
Jon
thanks
Jon
Re: Need More Power/speed!!!
If you are putting on a larger throttle and ported intake, do the turbo AFM upgrade. Buy a Air Flow Meter from a 280zx turbo. Take out the inside electric components. Put the AFM components from a non-turbo AFM inside the housing of the Turbo Meter. Then you'll have to adjust it untill your car runs at the correct richness. This will open up the bottleneck in your intake. Of course, use a cone K&N air filter on the front of your induction tube.
Shave the head slightly on your Z, and advance the cam sprocket one point to correct the slack in the timing chain. Raising the compression helps with torque as well as makes way for a performance cam and new followers.
thetorp
05-04-2016 05:39 PM
audiofreak97
11-19-2010 06:20 AM
bluesman1958
04-15-2004 03:31 PM
