need help ASAP!! 280zx 1983 N/A
Old Dec 16, 2014 | 03:20 PM
static.wise's Avatar
The transmission's refill and drain plug bolts will not bulge.
I am working on my driveway with very little leverage underneath.
Anyone have any advice on anything else I can use besides a wrench.
thanks.
Old Dec 16, 2014 | 06:22 PM
Steve260Z74's Avatar
Use a map gas torch to heat up the area around the plugs.
Old Dec 16, 2014 | 07:06 PM
ok ill try it thanks
Old Dec 16, 2014 | 07:23 PM
beg3yrs's Avatar
I had to use a torch to get mine off. This was after a good soak with PB Blaster didn't work.
You might consider raising the car on jack stands so you'll have more room. Be VERY careful with jack stands. Make sure all four corners of the stand are solidly in contact with the floor and then make sure the car doesn't wobble AT ALL before you go under there. If it does wobble, find the culpable jack stand, adjust and repeat the process.
Tosh280zx
Oct 31, 2013 08:33 AM
mottabam
Jan 6, 2009 07:53 PM
LT11
Sep 11, 2008 03:07 AM
dr. buddha
Jan 12, 2004 10:29 PM
