Low Oil Pressure
Old 12-05-2002, 07:42 AM
Re: Low Oil Pressure
I have heard a howling transmission before, but it seemed to increase with speed and was definatly from the tranny, not the rear. Its not uncomon for a rear differential in a Z to howl while cruizing in 4th or 5th gear. As far as the rpms go... could it be a whine coming through the rear speakers? Sometimes your tach line will be close to the power wire of an amp that someone installed. :-)
The low oil pressure "could" (and most always is) a bad oil pressure sender unit. They opperate differently in most every circumstance when they go bad. Its $50 to buy one from Nissan just to see. Maybe ask the owner to buy it... or the dealer? anyway, that would be my guess. Or they are easy to replace. Bring one from another Z that has good oil pressure readings and then plug it in and see if it makes any difference. If so, put the bad sender back in knowing that the true oil pressure is fine.
Bleach is offline
FubarI33t
04-27-2010 08:45 PM
FubarI33t
12-12-2009 10:03 AM
tonsoffun300zx
09-21-2009 10:51 AM
y2daniel1981
10-25-2006 10:24 AM
91zxtt
03-05-2004 11:00 AM
Quick Reply: Low Oil Pressure
