heres what i did, and some other options.
Old Oct 21, 2001 | 11:03 PM
Ghostz's Avatar
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re:need radio harness color codes
Lisa,
Although I am not as familiar with the 280s, I know that when I installed the stereo in my 300, I just ran all new wiring. It seemed to save alot of time and hassle, and it also allowed me to run higher quality wiring to the amp and speakers. As far as the power ant. goes, most new head units now have a plug in for them, so that shouldn't be much of a hassle, although I know alot of people that take those things out, i know mine (pia) was removed after a chance car wash (don't ask) helped remove half of it. Running wire isn't that bad though, just depends on how much work you want to go through. Someone who has done it on a 280 would know more than me though. If you do decide not to use the old harness, just make sure that you cap off, tape off, rip out, or in some way make absolutely positive that there are no live wires floating around from the old harness.
Good luck
Ghostz
Old Oct 23, 2001 | 12:38 PM
Re:rewiring and kick panels
Yes, there is one live wire in the original harness, used for the radio and the power antenna. (so it can go down after the car is turned off) So be sure to cap those wires off as mentioned.
I ran into the same problem and ended uprunning my own wires. I used a quick-disconnect strip to plug in power, ground, and all four speakers so I can swap out radios or remove the radio for maintenance. That worked great.
The rear speakers in a 280zx are no problem, but what about the front? I have been trying to make plans for a custom panel above the driver's legs to mount a speaker, but I may not have leg room if I angle the speaker forward. I am interested in knowing how eureozx is going to make kick panels for 6" speakers.
Niku-Sama
Sep 5, 2008 08:56 PM
one_fast_300zx
Dec 14, 2006 10:53 AM
chinesekid
Dec 5, 2006 10:09 PM
SHADY280
May 3, 2006 11:14 PM
Skully
Apr 14, 2006 10:57 PM
