Engine Cooling
Old Sep 9, 2003 | 09:02 PM
gr8gatZby's Avatar
Engine Cooling
I recently had to take off the original clutch fan and use an electric fan relayed based on the temp. The problem is when I am stuck in traffic it doesn't cut it. I normally runs, half on the dial, but if I am not moving at all, it will start to creep up pretty far. Are there some good fan setups people use currently, or should I upgrade radiators too? Anyone ever mount a fan to the front of the radiator to draw more are thru? I plan on moving to Arizona in a few months, and I know my it won't take that heat, especially when I need the A/C.
Old Sep 10, 2003 | 05:57 AM
preith's Avatar
From what I've read, the fan will work more efficiently when pulling air through as opposed to having it in front pushing. You might want to try hooking up the fan via a manual switch. It seems everyone I've talked to who had the thermostat switch was not happy. I did not have good results either.
Phil
Old Sep 10, 2003 | 01:47 PM
auxilary's Avatar
the Dude
as others said, run a puller fan instead of a pusher, and you also want to have a shroud. They really help when it comes to keeping the car running cool. Manual switch is also a must
Old Sep 11, 2003 | 07:53 AM
Originally posted by AllmyZs
...all my Z,s had oil coolers.
haha! All your Zs?
Old Sep 19, 2003 | 06:32 AM
gr8gatZby's Avatar
Thanks all
Thanks everyone for your replies. Another question, I recieved an offer for an oil cooler w/o the adapter for I think $45, is that decent? How much are they on MSA? Is it a pretty simple installation? Where should I mount the oil cooler radiator?
Old Sep 19, 2003 | 06:37 AM
gr8gatZby's Avatar
Questions for Prieth
Are you running an oil cooler on your setup? I was told, or I read, that a seperate thermostat should be used to warm the oil before entering the cooler if in our climate.
Old Sep 19, 2003 | 04:31 PM
gr8gatZby's Avatar
Phantom,
Thanks for the insight. What to sell me your oil cooler then? I'm running an basic setup. Small mods really, big bore kit, msa cam, centerforce clutch, alum flywheel, maybe soon some headers, 60mm throttle body, NGK fuel injectors, msa dist. and the most important...factory air.
Well, I am currently having a problem, and I'm in milwaukee. I'm just preparing for AZ!
Old Sep 22, 2003 | 10:18 AM
preith's Avatar
I agree with Phantom, if your motor is mostly stock, one isn't needed. I am running an oil cooler, but this is for a road race motor. I don't know if a thermostat is a must, but I'm using a Mocal with AN fittings machined on it. One from Permacool is much cheaper, and is pipe threaded with barbed fittings. I tell most people to use a radiator style cooler instead of the tube with fins design. By far the best deal I could find anywhere was through Racer Parts Wholesale.
JanS
May 2, 2013 03:55 AM
buddy32
Feb 3, 2012 07:10 AM
bherd
Apr 15, 2007 10:33 PM
Heat Rave R
May 31, 2005 02:21 PM
AllmyZs
Oct 15, 2003 08:00 AM
