Dual hood vents
Old Sep 24, 2002 | 09:44 AM
Re: Dual hood vents
Air box? The 280Z has an aluminum intake manifold, and that doesn't usually rust. I think they came both un covered from the factory and someone put a cover on one side for some reason. Maybe for winter driving. I would take it off and leave both sides open. If you think any of the electronics on the right side are getting wet, you can put the cover on that side or try to fabricate a plastic cover for your electrical components.
Old Sep 24, 2002 | 01:54 PM
Re: Dual hood vents
That's what he was saying. The driver's side (left side) has a plate underneather the vent that prevents air from cooling that side. That is why I suggested he remove that plate.
Also, this is not a turbo ZX or a 240Z. It is a 280Z. Please read what the buy posted originally.
Old Sep 25, 2002 | 09:58 AM
Re: Dual hood vents
Ok, so you got the vents in 1976, while in the US and Canada it was the 77+ Z's. I'm not sure on the early 280zx, but my 1982 280zx (turbo style hoods) has a very large air duct on the left side that is completly open. No shields. There is a shield inside the engine compartment that deflects air away from the brake cylinders and down toward the exhaust. That makes good sense though, to help draw the air down around the exahust and out under the car. The right side has the smaller vent as you know. It is open underneath (no plates) but doesn't look like it has much use. The only thing that gets a little wet is one side of the battery. The ZX engine compartment is wider, and therefore the electroncis along the side are pretty far away from any openings.
My triangular strut tower bar is right below the large vent. You can see it easily there when the hood is closed. It probably blocks some of the air flow, but I'm running an N/A motor.
bigdoggin
Dec 18, 2015 12:20 PM
cpark_12
Nov 27, 2012 09:42 PM
smoorenc
Nov 23, 2012 08:00 AM
cesar280z
Apr 11, 2012 10:16 PM
ZChief
Jun 29, 2007 11:11 AM
