Car idles, but dies when you step on the gas.
Old Apr 28, 2003 | 01:48 PM
zpeedracer25's Avatar
Check intake hoses after AFM for leaks or just loose. Sounds like you're getting unmetered air through the engine and not through the Air Flow Meter. I had similar problem on my 1977.
Old Apr 30, 2003 | 12:37 PM
What you've discovered is still consistent with some bad info from the AFM. I ran into the same thing on my 1977 with L28ET. It would idle and die with any throttle, but run great if I artificially induced fuel to the intake. I discovered that the ground wire to the AFM was broken at the connector and covered up by electrical tape, so it wasn't obvious. I fixed the broken wire and fixed the problem. Check the connector and make sure the AFM is getting power where it should and good ground. Hopefully you find something here.
Good luck,
Gary
280z78
Jan 14, 2015 04:08 AM
91z32n/a
Jun 5, 2011 02:19 PM
Heat Rave R
Other Cars
14
Apr 21, 2008 10:23 PM
90NA300ZX
Sep 15, 2005 02:29 PM
pearly whites
Sep 22, 2004 04:59 PM
