Cant get in drivers door from outside
Old Mar 29, 2004 | 02:52 PM
Z*Tech's Avatar
Latch
A new rod with a new adjuster is very inexpensive, shouldn't be a problem.
"Borrowing" from a wrecking yard is thief and not worth irritating the operators, especially if you might need their services again.
As far as using a nut as an adjuster,it works fine but you actually need two and tighten the one against the other to prevent them backing off.
Old Mar 30, 2004 | 07:33 AM
Alarm + power lock solinoid = keyless entry
then you can just shave the whole handle and lock from the outside and not worry about it again! Hook up the power lock solinoid to the vertical lever that used to go to the outside door handle. Don't forget a door popper spring.
duckyz
Jun 19, 2012 08:32 AM
zstickman
Oct 4, 2010 05:53 AM
3XAZOWNER
May 12, 2008 07:11 PM
xtasZ
Aug 3, 2004 07:50 PM
kewlcat
Oct 26, 2001 09:36 AM
