blow off valve
Old Aug 24, 2002 | 06:13 PM
lifegrddude's Avatar
Externally Wastegated
Re: blow off valve
Any blow off will do, it just depends on what sound you want and how loud you want it. I have an HKS SSQV and an HKS Super Blowoff that I switch between depending on what I feel like hearing. The SSQV makes a high pitched "peeef" noise and the HKS Super Blowoff makes a "psssh" sound. A T3 Garrett is what is on a stock 280zxt or 300zxt. It should do fine. Just double check the A/R if you can. I think the ones on the Z cars are a .63 A/R. Some other cars use a T3 but with a smaller A/R like a .48 for better spooling, but less top end breath. You might want to look into a T3/T4 since you going to build a turbo car, I've seen some for cheap on EBAY or ask a local turbo supplier they might be able to help you out too.
82ZXT
Old Aug 25, 2002 | 11:05 AM
zguy36's Avatar
Dead
Re: blow off valve
If you are going to be using fuel injection for you turbo motor, you will need a bypass valve instead of a blow off valve. The AFM will be metering the air that is being vented to the atmosphere and will screw of your air/fuel mixture. The bypass valve vents the air back to the inlet side of the turbo, giving you the same effect as a blow off valve, just without the noise and a little more plumbing.
-jeremy-
Old Aug 26, 2002 | 12:33 AM
Re: blow off valve
Since you're going for performance and don't really care for the sound, before you buy a particular bypass or blowoff, check and see how much pressure that thing will hold before it leaks. Different companies have different threshold pressures. Bypass valves that I've seen go for cheap tend to leak above 12 psi like the Bosch unit. Blowoffs usually go good up to about 18 like Blitz, HKS, Greddy Type R, some go more some less.
82ZXT
turboZ87.300
20
Apr 15, 2009 07:30 PM
hchase17
Mar 16, 2009 07:46 PM
Oxide
Mar 1, 2006 09:37 AM
Blue280zxTurbo
Oct 23, 2005 09:40 AM
haktmal
Apr 20, 2003 06:59 PM
