Battery and Starter Question
Old May 12, 2005 | 07:07 PM
ZDriver85's Avatar
I'm almost embarresed to ask this...
After changing out my clutch on my stock 240z, i realized that my dad(who was helping) took off the positive battery cable when taking off the starter. Neither he nor I know where the battery cables are supposed to connect to. Im pretty sure I have the negative hooked up right (on the top of the starter) but could anybody take a picture, or specificicaly describe which cable goes where just so I make sure that I don't fry the starter or something of the sort. Thanks
Old May 12, 2005 | 10:16 PM
Fast240Z's Avatar
the positive cable goes on the starter as well. It goes on the little threads that stick out, and the negative cable goes on the bolt that goes to the transmission.
Old May 12, 2005 | 10:20 PM
theramz's Avatar
I have a present for you...
The negative cable is bolted to the bell housing with the upper mounting bolt for the starter. The positive goes to the large copper terminal on the starter solenoid. If you need a picture let me know.
Old May 13, 2005 | 03:39 AM
ZDriver85's Avatar
Is there another wire comming off where the positive should be going?
CaseyNuThang
Jun 22, 2013 08:43 PM
CindyinPA
Jun 21, 2007 07:23 AM
wgc_3
Nov 2, 2006 09:37 PM
ZDriver85
May 14, 2005 12:21 AM
AlongCamePeter
Sep 12, 2004 06:20 PM
