Bad Ffp?
Old Feb 22, 2007 | 08:03 PM
skittle's Avatar
Taste My Rainbow
Bad Ffp?
i'M HAVING ISSUES WITH MY FFP. wHEN I'M DRIVING AND I MASH DOWN ON THE GAS AT AROUND 4K MY CAR SLOWS DOWN DRASTICALLY. i'VE CHANGED OUT THE FFP A FEW TIMES. ANY OTHER IDEAS? i WANT TO GET AN ADJUSTABLE FFP BUT TALK ABOUT EXPENSIVE.
Old Feb 22, 2007 | 08:38 PM
um... did I miss something? What's an FFP?
Google searched...
Family First Party?
Fresh frozen plasma?
Fund for Peace?
Old Feb 22, 2007 | 08:42 PM
skittle's Avatar
Taste My Rainbow
My Bad I'm Drawing A Blank On What Its Called Dammit!!! Stupid Migrane.. Ffp Is A Fuel Flow Proportioner (f-16 Thingy)
Fuel Pressure Regulator I Mean... Thats It Right?
Old Feb 22, 2007 | 08:47 PM
Ah! yes... fuel pressure regulator (FPR). Adjustable ones are cheap... it's the rising rate ones that are expensive (and not needed on a non-turbo motor). Why do you suspect the fpr? Have you tested the fuel pressure & a/f ratio at the time it loses power (aka fuel pressure & a/f gauges)?
Old Feb 22, 2007 | 08:49 PM
skittle's Avatar
Taste My Rainbow
Nope Cause I'm Driving On The Freeway When It Happens. I Had To Get A 30 Day To Drive Legally Until I Can Get Me Lights Fixed
Old Feb 22, 2007 | 08:53 PM
Hook up a fuel pressure & a/f gauge to diagnose the problem. I personally think it's more likely to be an AFM prob than FPR, especially if you've just replaced the FPR.
Old Feb 22, 2007 | 09:59 PM
skittle's Avatar
Taste My Rainbow
Ok Will Do, Where Do You Get A Adjstable Fpr?? And How Much? LUCKILY I HAVE 3 OR SO AFMS SITTING AROUND. i'LL DO THE REBUILD ON THE ONE THATS ON IT NOW, AND ADJUST IT.
Old Feb 23, 2007 | 06:28 AM
ebay... I have one just like this (Works great as an ajustable fpr... the only draw back is that is doesn't hold fuel pressure when you turn off the car... and the gauge isn't liquid filled, so you don't get a super accurate reading... but for $20 ya can't beat it): http://cgi.ebay.com/ebaymotors/RED-F...86068590QQrdZ1
Old Feb 23, 2007 | 07:52 AM
skittle's Avatar
Taste My Rainbow
hmmmm looks good, post a pic of it on your car?
Old Feb 23, 2007 | 07:53 AM
Old Feb 23, 2007 | 08:23 AM
so stumbling at above 4,000 rpm consistantly might be the AFM?
I'm having little issues but I wasn't going to worry about it until my wastegate gets fixed. 4300rpm submles every time under boost.
I'm still working on my A/F ratio gauge install
Old Feb 23, 2007 | 08:57 AM
Well I'm not saying I'm sure that's the cause, just suggesting to Skittle (and in your case too) to check the fuel pressure & a/f ratio when it happens.
Old Feb 23, 2007 | 09:37 AM
skittle's Avatar
Taste My Rainbow
will do thanks
Old Feb 23, 2007 | 11:03 AM
yes, I do want a remote mounted fuel pressure gauge on my dash right next to the A/F gauge. Those are not cheap. The one on the fuel rail was only $18
As Skittle said, its hard to check the fuel pressure on the rail when you're going 80mph, wide open throttle, in 3rd gear.
I also noticed last night that my plastic fuel injector holders are breaking apart! 7 months old and already destoryed. Maybe my injectors are backing out at that rpm? hmmmm.... I'll put new ones in when I replace the manifold gasket next week... after my Pulsar passes emissions!
Old Feb 23, 2007 | 11:16 AM
A local Z'er said he just T'd the fuel line & ran the fuel gauge up to the windshield where he taped it so he could see the fuel pressure while driving. Sure... it might be a big ghetto, but it worked.
Old Feb 23, 2007 | 11:38 AM
Or I could do like NismoPick and put a camera on or under my hood pointed at the gauge and run an in-dash LCD screen simple is always the best way!
Old Feb 23, 2007 | 11:41 AM
Dood! I like where your head's at!
Old Feb 23, 2007 | 03:16 PM
skittle's Avatar
Taste My Rainbow
ohhh instead of an lcd make it go to a hud so you'll always see it infront of you.
Old Feb 23, 2007 | 07:09 PM
2 of my plastic fuel injector holder are breakin apart to... ill have to make do until i got money... but teh car aint running yet so i guess no big. lol those things are crappy though.... they should be like a urethane or some sort of solid rubber material...
and how would you get a HUG to display your FP guage though? lol....
Old Feb 23, 2007 | 08:45 PM
GM quick release injector clips FTW kids:
Old Feb 23, 2007 | 08:48 PM
Carl's Z's Avatar
Those look just like the pigtails I got at Autozone for something like $1.99 ea...
Old Feb 23, 2007 | 08:52 PM
you can get tehm for 89 cents a piece.... theres a link on pallnet's site for them.
Old Feb 23, 2007 | 09:30 PM
skittle's Avatar
Taste My Rainbow
Awww Sweet, Snowy I Have Metal Injector Holders... Never Seen Them Before Until I Got Me New Z
Old Feb 23, 2007 | 10:32 PM
BASTARD!!!! lol.... well its only 2... i can make do for now... i have my pallnet fuel rail just chillen (need an FPR) and my buddies DSM injectors... but i need a way to control them thats where im on a snag... cuase im BROKE!!!! lol... gotta get me a SAFC or a standalone... that or SAFC and then a method of eliminating the stupid AFM. but... the first challenge is getting it runnin. lol. and in the process making the motor shiney or at least presentable again.
if i start making money again i want an aeromotive FPR... adn i guess ill need a guage otherwise i wont know what its all set at.
