'77 FI Z has hesitation
Old 03-11-2003, 05:33 PM
beechkingd's Avatar
I've done quite a few thinks to my '77 but ever since I put on some MSA headers it has had a hesitation problem.... I've changed the injectors and some leaking vacuum lines. It starts ok usually but only seems to only have three power settings. Idle, accelerate like hell and cruise. In between idle and accel it misses and backfires a little... any ideas on where I should look next? Also, the timing is dead on, both valve and ignition. I'm thinking thermotime switch/cold start valve, airregulator, or maybe the fuel press reg just don't what to throw them all at it if I can help it
thanks for your suggestions.
beechkingd is offline
Old 03-18-2003, 08:24 AM
bumblezee's Avatar
I had the same problem!!!
did you use the msa intake and exsaust gasket??? if so, your gonna have to take it all back apart. See the msa gasket is made for 240's - 280's... so the holes in the gasket for the injectors to spray the gas in.. well there not cut out in the gasket. You are going to have to either buy a new gasket, or cut the holes in for the injectors. I thought i had a FI problem... so i went to carbs.. but after taking my fi off to switch to the carbs i found the problem with my gasket.
bumblezee is offline
Old 03-19-2003, 02:52 PM
I've been running the MSA header gasket on my 280zx for years and have no problems. I never did check to see that it has fuel injection cutouts.
Bleach is offline
Old 04-21-2003, 02:57 PM
beechkingd's Avatar
FIXED!!!!
I finally removed the gasket material from the injection ports. What a difference, all the stuff I've done just for the wrong gasket!!!! Thank you all for your suggestions. And I will pay more attention to MSA stuff from now on. Thanks again.
Old 04-23-2003, 09:09 AM
bumblezee's Avatar
hey!!
im glad you found it!!! i drove a whole summer like that. And then convinced that my fi was shot, i convrted to carbs.. in that process i found that out about the MSA gasket.. it really sucked.. glad you found it before you gave up
Old 04-30-2003, 05:15 PM
beechkingd's Avatar
I suffered w/it for the last three years..... lol only on weekends though
84z31nonturbo
04-15-2008 04:18 AM
flightforlife07
06-15-2007 01:13 AM
FubarI33t
01-13-2007 03:30 PM
ShadWarr1
07-15-2001 12:14 AM
Quick Reply: '77 FI Z has hesitation
