75' 280z Starter not receiving power?
Hello, I just bought a 1975 280Z.
The starter works when I jump it, but not when I turn the key (ignition). I verified there is no power coming from the wire (connected at the starter) that is supposed to turn the starter on.
Also, the fuel pump turns on and pumps fuel, I hear a cylinder under the clove box operating. All fuses are not blown and the two fusible links are hard wired.
Any ideas of what might be bad or what I can check up stream from the starter starting wire that might be bad?
Thanks,
Robert
Thanks,
Robert
Listen for the inhibitor relay. if its not clicking on when you try to start it then its the neutral safety switch.
If that not the issue then your in the same boat I'm in and im still trying to track it down. I think its the connections in the key switch.
Guys I must apologize,
I pulled a Newbee mistake. I had the car in neutral. Thats why the starter wasn't turning. So the neutral safety switch was doing what it is supposed to do. I guess I verified it operates!
1) I am getting spark at the plugs but no combustion.
2) I'm keeping the battery 12.75 and above. I hear the fuel pump pumping when the car is in neutral but I don't hear it pumping when the starter is cranking.
Any thoughts on these two?
Thanks,
Robert
Thanks,
Robert
I believe if you check the wire that goes to pin 72 for the fuel pump relay, you will find it has continuity with ground. When you turn the key to start, the coil is energized via pin 76. It is from the black/yellow wire that is hot when the key is in start. This closes the contact that allows the white/red wire to complete a circuit with the green/blue wire that goes to the fuel pump.
Hello Guys, I'm barely keeping up with you (but having fun)
Are you talking about wire 72 (fig. EF-41) connecting to pin 85 (fig. EF-41)? I correlated 85 (fig. EF-41) to 85 (fig. EF-80 Section 7-2 Fuel pump relay check)
I am not getting continuity between pin 85 and a fire wall ground.
However I did start following the Continuity Check procedure for "Condition Engine will not start." Section (5) Fuel pump contact points - passes; (3) AFM - passes, Section (4) ATS - passes.
El_Colombiano
Jan 18, 2013 03:36 PM
AlongCamePeter
Sep 12, 2004 06:20 PM
