4 or 5 speed faster?
Old Aug 18, 2002 | 03:57 PM
Re: 4 or 5 speed faster?
Here's the deal, in simular years, the 4-speed and 5-speed manual transmissions have the same acceleration! 4th gear in BOTH is always 1:1 ratio. 5th gear is just an overdrive. The L28 doesn't have much power in 5th gear, but you do gain a little bit of top speed with one. You can go about 100-115 in 4th gear depending on what rear gear you have. My 280zx with an R200 at 3.9:1 and in 4th gear (1:1) hits 99mph at 5200 rpm. That is where I shift because that is peak horsepower with my fuel injection. You can still revv higher. If you have a higher gear ratio like a 3.54 found in most 240Z and 280Z's, then you can go a little faster. When I shift into 5th, I can accelerate some more, but I can't reach 5200 rpm again because I don't have enough power to get up there... a turbo engine would move farther.
Off the line, you'll be the same. As in, if you compare a 1977 280Z with a 4-speed to a 280Z with a 5-speed. Thing is, they changed the gear ratios of 1st through 3rd a little bit through the years. As the rear end ratios went lower, the lower transmission gears seemed to go a bit higher.
280Z 5-speeds have a 3.3 1st gear. same up to 1980. 1981-83 280zx n/a have a 3.0 1st gear but also have a higher 5th gear so they do better with a lower rear gear. (which they have) The T-5 has a 3.5 1st gear and a high 5th gear so it gets you off the line fastest.
But, since 4th gear is the same in the T-5, you have larger jumps between gears. Its also something to think about. The best transmission is to use the 1981-83 280zx n/a. It has the highest 1st gear and since 4th gear is 1:1 like always, it is the "closest ratio" transmission. Put in the lowest rear gear you can find so you can still launch off the line. with that transmission, 4.11 rear minimum or try to find a 4.375 or 4.625 R180. You can also buy a new R200 in those ratios from NISMO, but they cost about $700 or so. (they even come in LSD)
:-D
did you understand all that?
Old Aug 19, 2002 | 09:18 AM
I would advise against using a 4-speed in there. Besides, I hear that the 280ZX has a longer transmission, so you probably already have a custom driveshaft? (unless you bought the car as it is now)
Keep your current transmisison and lower your rear gear to a 4.11
Can you max out your rpms in 5th gear? You must have a pretty powerful engine with good torque around 4500rpm! If you can't quite max it out in 5th now, then lowering your rear gear will give you higher top speed. You'll basically have a little more power at the rpm that you usualy can't go past and then you'll climb higher.
As far as 1/4 mile time, I'm not sure how much it will improve, but I would say probalby 2 tenths in just the gearing alone. You'll like the new launch too.
Changing to a 4-speed to get a lower 1st and 2nd won't really do all that much for you. Going too low of a 1st gear is hard because you have too much torque. It will require careful launches to not just spin the tires. What you need is the best combo of low gears and close gears. Like I said before, you have (in my opinion) the best transmission, so go with a 4.11 rear end or 4.375 if you can find one. 4.11 is probably best since it will still allow you some crazy top speeds. 4.375 might not go as fast as you like.
entropy31
Jan 10, 2010 08:44 PM
Jerkif
May 29, 2005 03:09 AM
Copper727
Dec 3, 2003 08:05 AM
zkyle
Dec 9, 2001 11:25 AM
