280zx shut below 3000 rpm
hi every one my zx280 1979 wont work below 3000 or 2500 rpm
i changed the fuel pump air filter spark plug....
the car run good at high rpm but if i remove my leg of the gas pedel it well shut like if i cut the ign needd help
Sounds like the car doesn't know when it's in idle, or the idle is set too low. Can you give us a little more information on the car? have you downloaded the FSM that corresponds to your car yet? It's your greatest resource: XenonS130 - S130 Reference
EDIT:
Did you check the gap on your spark plugs before you put them in?
EDIT:
yup i checked the gap also i i have tried every thing in the afm ,,,
the car well eork for 3 sec and shut of the fuel pressure is ok and their is spark and the injectors getting puls i dont know what to do else
Give us a little more information here. Is the car Turbo? or N/A? Think about things that may have happened right before the car started to run poorly, did you replace anything? change anything?
With a little more info we can help guide you a little better.
Chris gnap
Apr 14, 2014 09:20 AM
Hamer007
Mar 27, 2013 08:55 AM
