280zx: Can someone check some wiring
Old Sep 19, 2002 | 09:45 AM
lifegrddude's Avatar
Externally Wastegated
Re: 280zx: Can someone check some wiring
Well, I'm at school for now so I can't give you a wiring description, but if you can't find the wires related to the fuel pump, you can wire in a switch to run the pump. In the back of the car under that foam padding thing, you'll see this harness. It will have two wires. All you do is disconnect the harness, and ground the ground wire (use a multi meter to find which it is since I don't remember color), and wire the positive to a switch. From there, all you need is 12V power source for the switch and you can manually turn on your fuel pump (kinda like the race cars do). That will give you a temporary fix till you get some help on the wiring. Good luck!
82ZXT
zeeboost
Mar 7, 2012 09:55 AM
jginther1981
Mar 3, 2011 09:21 AM
archdragon
Sep 15, 2007 11:32 PM
nismo619
20
Oct 30, 2006 08:26 AM
81 Black L28E
Apr 22, 2006 02:22 AM
